Old 07-14-2020, 06:53 PM
XNA XNA is offline
Default removing ring from recordings
Is there any way to remove ringing from a recording that was captured at a live event? My client gave me their recordings and apparently their FOH mixer was having troubles with feedback/ringing. is there any way that I can at least reduce the ringing?
MacBook Pro 16in M2 Max 2023
32gb RAM
2TB SSD
-Running-
Pro Tools: Studio 2023.9.0
Old 07-14-2020, 09:55 PM
Sardi Sardi is offline
Default Re: removing ring from recordings
Izotope RX.
If you have a clean section of the offending feedback, you could analyse it and use RX to suppress the offending noise.
Spectral analysis will help as well.
Old 07-14-2020, 10:36 PM
Ben Jenssen's Avatar
Also, the old fasion way; use a narrow band eq boost and swipe up and down to single out the frequency and then cut to eliminate it.
ring mods Josh523 AAX Plug-ins 1 09-21-2015 05:10 AM
Phone Ring EQ FX?? jgiannis Pro Tools 10 2 09-01-2015 06:24 AM
Ring modulator musicman691 AAX Plug-ins 12 03-05-2015 04:17 AM
ring mod for vocals eric22rr Virtual Instruments 0 06-24-2009 07:08 PM
Ring modulator Mike62858 Pro Tools M-Powered (Win) 1 06-11-2007 08:56 PM
