Old 01-22-2011, 02:30 PM
careyletendre careyletendre is offline
Default I sure wish the Mix window was dock-able.
Having to cmd + = between them is a pain.
Cheers,
Carey
Old 01-22-2011, 02:41 PM
Richard901 Richard901 is offline
Default Re: I sure wish the Mix window was dock-able.
If you using a Mac, here are two ideas.
1. Assign a mouse key to cmd + = with SteerMouse ($20). This makes it very easy to switch between the Mix and Edit windows.
30 day demo at:
http://plentycom.jp/en/steermouse/index.html
I use this all the time. I find it much faster than even using two monitors for Mix and Edit.
2.Use SizeUp ($13) to "dock" the Mix and Edit windows.
Demo at:
http://www.irradiatedsoftware.com/sizeup/
Richard
Pro Tools 2023.9
Ventura 13.6
Old 01-22-2011, 03:02 PM
Thanks for the tips. Yes i'm on a Mac and i will take a look at your suggestions.
Carey
Old 01-22-2011, 03:46 PM
Bill Denton Bill Denton is offline
Unless I'm missing something, you can resize the windows so they are both showing, either one-on-top-one-on-bottom or side-by-side.
Another trick I use on small screens is to set the windows up so they are "cascaded" with a little bit of the "back" window showing outside the "front" window. Then you can just click the "back" window to bring it forward..
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 01-22-2011, 04:03 PM
I have been using window configurations and tiling options as a workaround.
Carey
Old 01-22-2011, 04:43 PM
jayprotools jayprotools is offline
hey peeps
on nearly all OSX programs if you hold cmd & hit the key on the left handside of the keyboard between the "shift" & "Z" keys (don't know what its called but it has these signs `~
its very close to the cmd key, it switches between windows within the app.
I find it very convenient and it works on all programs, so its easy to learn & get it into ya workflow, try it now in Safari ....
Hope it helps
Old 01-22-2011, 05:34 PM
Originally Posted by jayprotools View Post
hey peeps
Hope it helps
That's a good point but in this case there seems to be not much difference between cmd+= and cmd+`(tilde) in terms of ease of use.
I would like the mixer to dock inside the main window in the same manner as the midi editor.
Carey
[IMG] code is Off
bouncing on dock Tina Meazell Pro Tools TDM Systems (Mac) 1 01-06-2009 04:15 PM
PT just bounces in dock ... help please wonderlover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-23-2007 10:14 PM
can't wait for OSX dock? NY909 Tips & Tricks 0 11-25-2002 04:34 PM
T20 dock??? babilonburning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-18-2000 03:01 PM
Media Dock with PT 5 AV Wellnitz Post - Surround - Video 6 06-01-2000 09:32 AM
