Old 05-02-2002, 07:57 AM
yavuzj yavuzj is offline
Default Charlie Steinbergs take on Different sounding audio Engines
I thought you might find this interesting;
"the 'Logic sounds better' thing is not new and always comes down to pan law
beeing 0 dB in Logic, as opposed to the defaults of -3dB in Nuendo and -6 dB
in Cubase. this also explains why 'Nuendo sounds better than Cubase',
because
higher panning law makes centered signals (such as bass and bass drum) sound
louder (= 'better') and 'more punchy'. one can argue either methods
endlessly,
i think the -3 dB default of Nuendo is a good compromise because most desks
appear to use this. however punchy your mix sounds is entirely up to you,
regardless of the panning law you choose; and if your mix sounds better when
you switch to a different panning law, then you should think twice about how
you mix in general at least, in Nuendo and Cubase, you can adjust the
panning law so to fit your 'taste'.
the idea behind -6 dB panning law is that when you would put your 2 stereo
speakers into 1 box, wherever you set the pan, there wouldn't be any
difference
in volume (loudness), and this becomes obvious when you listen to the mix in
Mono, because the sum of left and right when panning a channel is always
equal.
this is not true for any other panning law than 6dB.
using 0 dB on the other hand, when you are all to the left or right, the sum
will be 0dB, but when you pan to the middle it will become +6dB. personally
this
feels plain wrong to me (despite the math, just listening to it) and makes
me
insecure as to how much panning to apply, but it is really a matter of taste
(and what you are used to; if you come from Logic, you'd probably be much
better
off choosing 0 dB). as said above, -3dB appears to be a good compromise, but
whichever law you choose, your ears are the one and only final resort to
jugde
how 'punchy' you want your mix to be.
Goobers perfect summing bus. (simplified example)
Input from channel 1 =10
Input from channel 2 =3
Input from channel 4 =1
Add inputs together...
Output= 14
Now, how could any data massaging algorhythm improve on this? All integer
summing
busses should sound exactly the same until ditherd.
The only problem is that the VST engine uses a 32bit float, meaning that
mixing large and
small numbers could cause smaller signals to be lost due to mantissa
priority confusion!
sorry but this needs explanation...
the nominal range of VST floating point is -1.0 to + 1.0.
any signal going in or out the VST system is converted to this range.
as 'external' signals are always integer currently, they are limited to
maximum numbers (both positive or negative). so whatever
the integer format (16 or 24 bit), the maximum and minimum values that
those bits can represent are + 1.0 and -1.0 expressed in floating point
terms.
in a 32 bit floating point value, this will cover the mantissa
of 24 bit, so it is always *at least* as precise as a 24 bit integer
value (so it is at least 'as good'). the exponent is always 0.
considering a signal of 0dB peak, this means the largest values will
be + 1.0 and - 1.0 resp. smaller signals will go down to -144 dB with
100% precision, because the mantissa is 24 bits large (also there
is a sign bit). going below -144 dB is also possible, where the
farther you go, the less precise will the numbers become; not that
this could ever have any impact, because a) there are currently and
commonly no converters to deal with more than 24 bits nor b) is there
any analog equipment that i know which can deal with dynamic ranges
of over 144 dB anyways.
only when you drive signals above 0dB will the exponent get
changed. in this case the unbeleiveable headroom of the IEEE floating
point mechanism becomes active. it works like a VCA: when
you exceed 0 dB, the control voltage will rise, where below 0dB it
will be constant (actually it changes to a negative 'voltage' when
you get below -144 dB). as with the lower numbers, at a certain point,
there is a loss of precision, but this is very small unless you go
crazy with your signals.
this gets us to
This is where a small number dissapears when added to a larger one as the
integer has too
few bits to hold both values.
I'm assuming they use a 24bit number with 7 bit mantissa and sign.
It would have to a fairly extreme situation for this to happen, and I'm sure
it could not be
audible, but who knows? Using a floating point number may give better
results for sperate
channels in theory, but could cause problems when many are added.
'extreme situation', you can say that. for a signal of -140 dB
to be masked, you would probably need some +140 dB on the other end.
not only will this never happen in anybodys' studio (unless a plug
goes mad , but even if it happened would you not really be able
to hear that your -140 dB signal is gone, because your speaker mebrane
has arrived at the opposite wall meanwhile.
the bottom line of all of this is:
- first off we are dealing with numbers. we don't want any
colorizing so we 'only' need to be precise. maths can not be
cheated. if any digital system sounds 'better' or 'worse' than
another when playing back an unaltered signal and using the same
hardware, either there is some bug, or there is colorization
applied by intention.
- second, the nominal range of 32 bit floats is always 100% precise
within 144 dB (or 24 bits) (i think it's even 25 bits because we
have an extra sign bit but it's late and i'm too lazy to look it
up).
- third, there is an incredible headroom with floats as opposed to
integer values. there is loss of precision however when you exceed
the range of the mantissa (those 24 bits), but that only happens when
you exceed that range big time and even then, the change of the
numbers that result is in the range of 1 bit which is again inaudible.
and when you bring it all down again to the range that your converter
can handle, the 'imprecise bits' usually fall outside that range
anyways.
- fourth and finally, there may be problems when *converting* those
floating point numbers from and to integer numbers. we are currently
double-checking this so to make sure that when you render to file
(export audio), the outcome is exact. but even if we dumb programmers
create errors in this area would you not be able to tell the difference
(at least with 24 bit files), because again the error would be in the
range of 1 bit, which is measureable but no equipment can reproduce
it anyways. but yes, we certainly need to be 100% correct for your
convenience and we will.
that gets us to 'bus summing'. as somebody pointed out
earlier, this is in fact nothing but adding values; and this adding
operation is just as precise as your pocket (or scientific) calculator.
would you trust it?
BTW, Ksmith, did you hear about the test when the same tracks were summed in
a PT Rig
and the Oxford? The results could be put out of phase giving zero.
http://www.virtualstudio.org/VS_AUTO...T/00-02-15/117
I think both PT and the sony use integer busses though.
Either they both use the same 'summing bus' or we are all caught up in some
invented
problem.
possibly
How about a word from the people who write these things, Steinberg? No trade
secrets, just
perhaps some useful info to guide our ears. Is it better to mix with a
fairly hot reading on
the masters, or does that loose precision? Should we keep it fairly low and
export the 32bit
file to be normalised and ditherd?
in theory, you should not overdrive the channels more than +6dB and of
course
keep your master at 0 dB. this puts you on the 'mathematically prooven exact
side of the fence', so to speak. in practice, even if you drive many
channels
much into the red, it doesn't make for more than an inaudible (albeit
possibly
measureable) difference.
actually, floats behave a bit like analog equipment: if you overdrive it,
it does something on its own. but for what a float does then to become
perceivable, you would have to write a plug which drives your signal up
a few hundred dB's....certainly more than your analog tape recorder
at +6dB, which is clearly audible.
charlie"
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 05-02-2002, 08:42 AM
soundsurfr soundsurfr is offline
Default Re: Charlie Steinbergs take on Different sounding audio Engines
That was really cool.
By the way, what the hell did he say?
[img]images/icons/confused.gif[/img]
Soundsurfr
MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM
M-Audio Firewire 1814
Yosemite OS
Old 05-02-2002, 08:52 AM
BigRedButton BigRedButton is offline
I can't tell if I feel smarter or dumber after reading that. [img]images/icons/smile.gif[/img] [img]images/icons/confused.gif[/img]
I twist the pretty knobs and buttons till everything sounds "not sucky".
"Sometimes I doubt your commitment to Sparkle Motion."
BigRedButton / Jackson Jackson
www.jacksonbjackson.com
Old 05-02-2002, 08:53 AM
<font size="2" face="Verdana, Arial">Well he was explaining the panning law that exists in some hardware mixers as well.
In short, he was saying the different sounds of different DAW mixers are the result of the default panning gain. Otherwise they all add up numbers.
Yavuz AKYAZICI
Old 05-02-2002, 09:02 AM
Actually I would like to hear some comments on this subject form the PT programmers.
May be Brent?
Because, This is really interesting.
Yavuz AKYAZICI
Old 05-02-2002, 09:08 AM
Chris Winfield Chris Winfield is offline
Interesting - Mr Charlie sais that a change of 1-bit is inaudible, but ends his message saying that a gain change of 6dB is very audible. There was me thinking that every bit reduced the noise floor by 3dB, and would therefore be audible.
He's right about the converters though - there are none currently available that give a true 24-bit dynamic range, this is due to their poor jitter performance.
Old 05-02-2002, 02:29 PM
Phil O'Keefe Phil O'Keefe is offline
Vintech / Neve 1272's
Presonus MP20's (hot rodded)
Bellari MP110 (occasionally for extreme color - mostly bass DI)
Yamaha AW4416 preamps
Very rarely the Digi 001 preamps
Joemeek VC3Q's
And yes, you CAN hear a 1 dB change... you can actually hear LESS than a 1 dB change in some circumstances...
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Old 05-02-2002, 02:31 PM
<font size="2" face="Verdana, Arial">Yes, but i think he is not really saying that you can not. That is what i understand anyways.
Yavuz AKYAZICI
Old 05-02-2002, 03:02 PM
Mark_Knecht Mark_Knecht is offline
Don't know about you guys, but I seem to spend a considerable part of my day in 'mantissa priority confusion'. [img]images/icons/wink.gif[/img]
Mark
Old 05-02-2002, 03:03 PM
And I think that maybe this is why Rupert is Rupert and Charlie is Charlie...
Weird sounding audio after few seconds scontrer Pro Tools 10 3 08-27-2013 01:57 AM
New Rabbit Ears Audio SFX Library: Antique Engines sepulchra Post - Surround - Video 0 02-21-2012 11:06 AM
Replacement Jet Engines Pirate Post Aspera DigiDelivery 1 09-16-2011 05:14 PM
playback engines jimlongo Pro Tools TDM Systems (Mac) 0 06-21-2006 10:59 AM
Dragging sounding audio ?????? MR. BLISS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-25-2004 06:43 AM
