Closed Thread
Old 04-04-2023, 01:37 AM
chris.d chris.d is offline
Default How can i trust ProTools - why should i ever trust ProTools?
Mac Mini M2 Pro
OS Ventura 13.2.1
ProTools, 23.03.0.89 lastest, approved for ARM
RME Madiface USB
I just had my first 2 sessions
Nr. 1
Ordinary song recording session
In two days i had 2 DAE errors that ended recording in the middle of a take. (8 Tracks, 0 plugins used)
work around:
curse
appoligize
redo takes
Session Nr. 2 was a live-in-the-studio recording session. The band plays improvised sets of 30min.
DAE Error stops the recording after 22min into the first set.
(16 Tracks, 0 plugins used)
work around:
react fast
hit record again
5 Min later DAE error again
hit record again
after the set:
curse
appoligize
install reaper (2min)
have no problem for the next two days
(except that i know ***** how to handle the program and feel like a total dumbass)
was testing the previous PT version (rosetta .bla bla, don't remember the numbers...) with no issues
2 hours straight recording
64 tracks
192khz
32bit float
128 (smallest buffer)
64 reverbs on tracks
The first PT version i saw was 6.1
From 7.1 i used PT professionally as my main DAW, aprox 22 years
time and time again i've seen new PT versions and systems useless until somehow one finds the 'magic' combinations and tweaks.
In 2023, despite compability charts recommendations ProTools is basically useless in a live recording situation.
Why do we have to go through this?
With every single version update?
Once again I'm UTTERLY disgusted (for lack of original expressions)
AVID:
why don’t you get? its 2023!
we use 7GB/s writing speed SSDs
teraflop CPUs
Old 04-04-2023, 02:39 AM
Sardi Sardi is offline
Default Re: How can i trust ProTools - why should i ever trust ProTools?
Not downplaying issues you’ve encountered, but can I ask why you need 64 reverbs when tracking?
64 tracks would mean you have a reverb plugin inserted on every track. What for?
Your machine can probably handle it, but…
Old 04-04-2023, 04:54 AM
sw rec sw rec is offline
Agreed, first thing I’d consider is a better way to handle my workflow.
And it would help if you’d post the exact NUMBER of your DAE error…..
Old 04-04-2023, 05:05 AM
thin ice thin ice is offline
I feel your pain with what you hoped would be a perfect setup, but never judge any new piece of gear immediately.
Follow the trouble shooting help on this forum and watch that activity monitor to see if anything is hogging resources. "mds_stores" is Spotlight, which probably works hard on a new installation for a while.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 04-04-2023, 05:15 AM
its2loud its2loud is offline
The 64 reverbs were on the test session that actually worked for two hours without issue. That probably wasn’t the issue.
On the flip side, I ran a record with 2023.3 for 2.5 hours with 64 tracks. Not one issue. So 2023.3 works. Every situation is different.
Old 04-04-2023, 06:38 AM
Yes you’re right. I misread that.
Apologies.
Old 04-04-2023, 06:49 AM
simply to check the limits of the system...
to make sure that whatever i'll throw at it in the future that it will be up to the task!
e.g. a bloody simple 16 track live recording
Old 04-04-2023, 06:51 AM
i had no time to note, to screenshot, to 'whatever' as i tried to save the recording... went back to record ASAP!!!
Old 04-04-2023, 06:56 AM
it's not excactly that the mini had no time to adjust...
i installed OS and data (400GB of stuff on the intern, no external drive) weeks ago. worked seemlessly for all previous testing with the former PT 2022.
The Mini was on for at least 24 hours with PT2023 before the session / failure
Old 04-04-2023, 08:37 AM
gives's Avatar
gives gives is online now
RME is not my wheelhouse, but I assume you have all of the drivers updates etc.
It's the little things that can cause each unique system setup go off the rails.
Just a suggestion, since I know it's probably not, but you never know what has been done by other users.
https://www.rme-usa.com/downloads.html
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Closed Thread
My trust C|24 PSU.... gone Raggi ICON & C|24 1 12-08-2020 04:34 AM
Do you trust in Arturia/Protools 8 ? redmount Virtual Instruments 6 02-22-2010 02:56 AM
What Should I Trust? Kenny Gioia Pro Tools TDM Systems (Mac) 91 01-30-2007 11:06 AM
Which do you trust? Sacred Spirit General Discussion 2 05-21-2005 07:04 PM
Would you trust a plug in for this? Dopamine Pro Tools TDM Systems (Mac) 4 12-20-2002 08:08 AM
