How to create loopback?
I'm in the process of analysing the frequency response of my mixing room and the software I'm using requires a calibration of the soundcard. The software needs to determine the frequency respons of the sound card so I need to make a loopback in the sound card.
The manual says: "Connect the soundcard's line output directly to its line input - use the channel that will be used to make measurements" How do I achieve that? Im using the Mbox Pro 3:gen. |
Re: How to create loopback?
No one knows?
The program I'm using is called Room Eq Wizard. The program plays a sinus wave that's suppose to play through out the soundcard by a loopback so it can record the frequency respons. I don't know if this makes any sense, but i can't figure out how to do that. |
cable from output to input...
"Sometimes having limits keeps you sane"- Albee1952 |
Its just that I'm afraid of overload/destroy the sound card in some way, hence my question.
But if I route a 1/4" cable from the monitor output to Mic/Di input 01, would be safe? |
Loopback Test Failed | Incus Music | macOS | 0 | 02-23-2013 06:46 PM |
AD-DA loopback shootout - anyone? | Righty27 | Eleven Rack | 3 | 07-18-2012 11:37 AM |
adat loopback | uri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-21-2003 11:28 AM |
Midi Loopback & XP | _Dova_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-08-2003 07:37 PM |
Midi Loopback For Xp? | joncor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-29-2002 05:12 PM |
