Old 04-22-2010, 10:00 PM
Strebor24 Strebor24 is offline
Default Help with Axiom Pro 49
I thought that the Axiom Pro 49 was supposed to automatically map to Pro Tools 8 but it does not.
I opened an 'Xpand2' window and it is a joke. The E controllers adjust random parameters in X pand that make no sense at all and the modulation wheel adjusts the master volume (along with E4)!
Who mapped this thing?
I thought that it was supposed to be logical and 'talking' with Pro Tools?
Shuttle PC, XP Home SP 3, Core 2 duo 3.16 GHz, 4gb PC6400, 500gb SATA 3G HD, Mbox2 pro., Pro Tools 8.
Old 04-22-2010, 10:21 PM
Default Re: Help with Axiom Pro 49
Are the MIDI Controllers Peripherals setup? Is HyperControl on the Axiom Pro set to Normal?
Aaron Mulqueen - 001 HD Native
Old 04-23-2010, 08:06 AM
Thanks for the reply, yeah everything is working as it should, I'm just surprised at the pre programmed logic. e.g. page 1 in Xpand 2, someone chose some very odd parameters as default with the e controllers.
I guess I can use 'learn' to re program it the way I like.
I just wish too that Avid had put a little more thought into the general quality of the product.
The faders are cheap and the pitch bend and mod wheels are HORRIBLE! I used a MPK49 for a while and it felt very nice. It had killer wheels that felt more like playing an 'instrument' than pushing on a cheesy plastic thing!
Old 04-23-2010, 12:44 PM
Whilst in Plug-In Learn mode hold Start (Win) and assign plug-in parameters for custom plug-in map. Don't forget to export the map and set it as default.
Axiom 49 Help!!!! Versa MIDI 0 09-18-2012 03:32 PM
Axiom pro 61 - should I get it? johndavid MIDI 7 07-08-2011 02:10 PM
Axiom Pro 49 and Axiom 61, Prepheral issue? udhoshi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-22-2011 03:45 PM
Axiom 61 2nd gen davidlustrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-04-2010 09:29 AM
Axiom Pro 49 vs Axiom 49 JonnyGinese MIDI 13 09-18-2009 06:33 AM
