Old 04-03-2010, 07:14 AM
DragonBlight DragonBlight is offline
Default Arpeggiators
I would like to know how to use arpeggiators in rhythmic combination with a Pro Tools system. I think I would need the master Pro Tools system with a midi line out going to a midi thru device, which would go to the inputs of all my arpeggiators. My arpeggiators would be going to a midi merger to my interface's input.
The output of the pro tools system would be generating MTC for the arpeggiators, and MMC for other pro tools systems.
This is all just my theory so please tell me if I don't know what I am talking about.
Old 04-03-2010, 12:16 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Arpeggiators
Not quite enough info to go on, but in general, in PT make sure you select for MIDI Beat clock to go out to whatever it is you want to sync (assuming you've also properly set that up in the PT MIDI Studio so it is recognized by PT). Then, for each individual external device you want to sync, make sure you set it to receive MIDI clock info from the MIDI in, which would be PT.
For example, on my Yamaha Motif XS8, I can select MIDI sync for either external or MIDI (or Auto, but we don't need to worry about that here). On internal, the MIDI clock is whatever tempo I have set on the Motif. But, on MIDI, arps on the Motif will play according to the tempo clock sent from PT. that way it syncs up perfectly with the session tempo. I can layer arp'd voices too, such as some from Xpand and the Motif and anything else.
So, for whatever arp devices you're using, you need to figure how to set the equivalent parameters that way.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 04-03-2010, 01:05 PM
By sending MTC am I sending MIDI beat clock? Or is midi beat clock something completely different. Can I send these different signals out of the same MIDI cable?
I want to run this arpeggiator in loop play mode... that shouldn't effect the tempo right?
Old 04-03-2010, 01:12 PM
Slave the MTC via Pro Tools MIDI Beat Clock and switch the internal Clock of the MTC to External. You will need MIDI Out Pro Tools MIDI In MTC.
Aaron Mulqueen - 001 HD Native
Old 04-03-2010, 02:12 PM
So by generating MTC I am generating MIDI beat clock?
I think you misunderstood what i said, FILO. I want to have the pro tools session dictating the tempo to the arpeggiator.
Old 04-03-2010, 02:20 PM
It is you who is mistaken. Re-read my reply and read the Pro Tools Reference Guide and your MTC manual.
Old 04-03-2010, 07:11 PM
DonaldM's Avatar
Which is exactly what will happen if you read what Filosofem and I wrote.
Old 04-05-2010, 05:06 AM
I just want to make sure I can send all of these MIDI signals through one cable.
Old 04-05-2010, 07:41 AM
DonaldM's Avatar
Yes
Old 04-05-2010, 07:48 PM
You have a choice of 16 Channels.
Using Arpeggiators with PT 10 Jurupari Man macOS 0 01-29-2014 03:07 PM
good arpeggiators for PT LE 6.9? glankrudolph Virtual Instruments 1 11-04-2006 05:07 AM
A question about arpeggiators... AppleFunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-11-2004 03:18 AM
