Please help with this mac problem....
anytime i turn the computer on it ALWAYS gets hung up right before the extensions start loading, if i hit restart on the front of the computer it ALWAYS works the second time around. if the computer has sat for a while and then needs to be restarted again for some reason....same thing. ALWAYS gets hung up in the same place and ALWAYS works second time around. NO new applications have been installed, so i don't think??? it's an extension conflict.
Re: Please help with this mac problem....
Have you run Norton on your system hard disk? Zapped PRAM?
It's possible you might have some defective memory. The Mac OS runs a memory check when the computer is first booted up, but does not run the test when you restart. You could also have defective memory sockets on your motherboard (and that might require a motherboard swap). Try reseating all the cards and connectors. Blow connectors out with canned air, and use a good contact stabilant like Caig Pro Gold to treat edge connectors on cards and memory. Go into extension manager and select a base extension set, and see if the computer boots up fine with that set. As a last resort, reformat your system disk and reload all the software. (I know it's time consuming, but sometimes you can spend a lot more time fooling around with these sorts of problems.) Good luck, and hope you find the problem. Lee Blaske |
Also try starting up with all peripherals disconnected. With computer and external drives turned off, disconnect all external SCSI devices and also disconnect any external USB/FireWire devices besides your keyboard and mouse.
You might might have a hard disk driver conflict. |
I had a g3 for awhile that would do that. finally had to get a G4. what kind of computer are you using?
ripe |
i am currently using a 500 MHz (don't laugh) G4. [img]images/icons/frown.gif[/img]
Before this problem it worked good?
I've seen that happen with certain peripherals. Even Digi interfaces.... Try keeping all the Digi interfaces off when starting up.
Jerry Nashville, TN |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem | tylerparkinson | Pro Tools M-Powered (Mac) | 0 | 08-21-2009 02:20 PM |
digi 002/7.4 installation problem/not recordable volume problem | fifthflaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2008 01:28 PM |
Audio Regions Display Problem & Grabber Problem | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-25-2002 04:08 AM |
