Sound from Quicktime Player
I have tried searching the DUC for this. Please direct me to posts that address it. I just could not find anything doing a search.
I'm using an 002 and have put quicktimeplayer in the DigiMME Helper. I'm not getting any sound. Sweetwater said to switch to the sound card and use pc speakers... I know this can't be right. Well, fine, it will work, but switch to pc speakers? I don't want to switch to pc speakers, jeez! I'm missing something here, what is it?
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2 |
Re: Sound from Quicktime Player
With the 002, what is usually recommended is to use the computer's soundcard for computer sounds (Quicktime, itunes, etc) and then route the output from the computer's soundcard to the alt/src inputs. Then when you want to listen to computer sound, you press the alt/src to mon button.
However, if you really must have quicktime playing through your actual 002 hardware, there are some things you need to be aware of. One is the Digidesign wavedriver is a single client driver. You cannot use more than one audio program at a time with Digidesign hardware. (that could be causing your issue, and is whey I mention it). Otherwise, all you really need to do is to follow the instructions in the Wavedriver Usage Guide: Quote:
Hi all,
I'm having problems with itunes. I was running a previous version of itunes which was working fine. I've updated to itunes version 7.5.0.20 and now there is constant poping, blipping when playing through itunes. I've gone over everything outlined above but still can't get a fix. I'm running pro tools le 7 through an mbox 2. This happened to me in the past but i didn't have time to find a solution so i had to reinstall the older version of itunes, which worked fine once reinstalled. Any help would be greatly appreciated. Leif. |
An additional note re above problem--
The same conflict (blips when playing in itunes) occurred in the old version of itunes, but this was solved by disabling an audio driver in device manager. I've looked at this and can't see any other drivers that would be conflicting. Is it possible that older pro tools and newer itunes just don't work together? Are there any driver updates from digidesign that might solve this problem? I've searched digidesign site for updates but didn't come across anything promising looking. |
Fill out the feature request form and ask them to update the wavedriver to include a buffer and a buffer control panel.
spkguitar, thanks for your help!
spkguitar...thankyou very very much. I was at wits end as i had tried everything possible, and couldn't figure it for the life of me.
I'll follow that link and fill the request form as you suggested. Leif. |
QuickTime Player | alon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2012 07:03 AM |
Quicktime Player/iTunes sound characteristics | gracejames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-08-2005 03:58 PM |
Quicktime player in explorer or in xp | cpnraisnuts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-08-2005 06:13 PM |
PT6.1 with OSX and QuickTime Player setup | bart vleugels | Pro Tools TDM Systems (Mac) | 3 | 10-15-2003 05:38 PM |
MPEG to *.MOV ( Quicktime Player) | Erikmusicman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-02-2003 10:45 PM |
