Old 02-21-2007, 12:15 PM
Torchlight Torchlight is offline
Default SoundTools Phase Scope
I was reading the manual/guide for the Phase Scope (SoundTools PlugIn) and it appears that a reading of "0" zero on the phase meter indicates a perfect stereo image. Does that mean that if you have typical readings between 0 and +1 that your mix is out of phase. The guide further indicates that a reading of +1 means that you have a perfect monaural signal. Does anyone have an understanding of how to effectively use this tool? When I use my ears I know that my mixes are not out of phase but the meter typically fluctuates between 0 and +1.
Also, what exactly should I be seeing in the phasescope? What's good and what's bad?
Thanks,
Torchlight
Phase scope? Fullsound Recording Pro Tools TDM Systems (Win) 10 02-26-2014 08:15 AM
LEQ(a) metering, no more phase scope.... sparky3000 Post - Surround - Video 10 12-21-2013 10:12 PM
Phase Scope plug-in adcantly Pro Tools M-Powered (Mac) 0 04-18-2007 09:04 AM
Phase Scope Vs. LM100 Nathan W. Post - Surround - Video 6 10-17-2006 07:48 PM
