Old 12-07-2019, 03:16 PM
Scott.Brownlee Scott.Brownlee is offline
Default "Unable to import some files because quicktime is not installed"
That's the error I'm getting now when trying to import any kind of video file. From my three hours of internet futility, I understand Apple has ceased support for Quicktime for Windows, and that Avid was working on a workaround. Does anyone know if there is a solution to this? As it stands, I cannot add any video files to my Pro Tools sessions, which is a bit of a kick in the teeth when you're doing a film soundtrack...
I have tried a new install of Pro Tools (twice), before and after reinstalling Quicktime. Quicktime Player just says I need to install Apple Application Support, which I also cannot find.
My specs:
Windows 10 64-bit, Intel i7-8700 3.20 GHz, 6 cores, 32 GB RAM, SSD for main Windows drive and Pro Tools, instruments on a combination of internal HDD and external SSD (USB 3.0), Pro Tools sessions stored on internal HDD, running Pro Tools 2018.12.0, with a Scarlett Solo audio interface.
Old 12-07-2019, 04:00 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: "Unable to import some files because quicktime is not installed"
For Audio, here’s a great way to install the QuickTime you need for Pro Tools on Windows, without the stuff that’s flagged as “bad”:
https://www.pro-tools-pc.com/apple-q...security-risk/
Don't know whether the "Quicktime Web Plug-In" is required for Video (I don't use Video) - see the above link for details
Pro Tools Studio 2024.3 * Studio One Pro 6.6 * Harrison Mixbus 10 Pro * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 & Air 32 MINI * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock * 3 TB Samsung SSDs * 3 Screens: 15.6” Laptop & 24” BENQ LED GL2450-B & Samsung 27” CT550 curved Monitor
Old 12-07-2019, 04:08 PM
ChuckS ChuckS is online now
Apple Application Support is installed with iTunes. You can selectively uninstall any parts of iTunes and the Apple stuff you don't want after the install.
The most recent QT for Windows is here: https://support.apple.com/kb/DL837?v...S&locale=en_US and may have the App Support included.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 12-08-2019, 07:16 AM
Thanks, but I've tried that particular QuickTime installer five times now to no avail. Even when I custom install to just have the QuickTime Essentials, I get the same Pro Tools error when trying to import any video file. Any other ideas?
Old 12-08-2019, 08:09 AM
If it's still asking you to install Apple Application Support, install iTunes for Windows. That installs both the 32 and 64 bit Apple App Support. You can check to see what's already installed in the Programs and Features Control Panel.
Old 12-08-2019, 08:17 AM
Unfortunately, I can't even get that far anymore as I can no longer find any executable QuickTime program to test. That's where I got the "Apple Application Support" error before. I'm trying a full system wipe and reinstall first, and if I'm still getting the QuickTime error in Pro Tools, I'll try installing iTunes and let you know.
Wish me luck...
Old 12-10-2019, 12:49 PM
Well hallelujah, that worked. All I had to do was wipe my entire system clean and start over again. Three days later after reinstalling all my Stuff, I can now import DNxHD videos into Pro Tools.
No problem whatsoever.
MP3 file "cannot be imported because quicktime is not installed" librabby Windows 2 09-17-2014 10:20 PM
Unable to import some files because QuickTime is not installed? Mitchdeathshadow Windows 1 08-14-2013 09:29 AM
Can't import video "Avid engine not installed"??? garnoil Post - Surround - Video 9 10-08-2012 04:45 PM
MP3 file "cannot be imported because quicktime is not installed" JayKan Pro Tools 9 1 07-20-2012 04:16 PM
