"add meter changes" shorcut ?
Someone knows the shorcut for the function: "add meter changes" (instead of clicking on the "+")? PC Pro tools HD-12 NO. Thank you.
Re: "add meter changes" shorcut ?
Right-Click - Insert - Meter ? (insertion in a clip at desired position)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thank you, but I want a keyboard shortcut. This is more efficient.
Ok, the shortest is: Cmd + clic.
Ok, then you might say so directly in your first post.
The shortest for me would be: assign the command from the menu "Event - Time Operations - Change Meter..." to a selfmade shortcut via Autohotkey; and assign that new shortcut to a button of an Expertkeys EK128 (or any other additional keyboard of that kind) : a single button press to fire that command.
I know nothing of Autohotkey. From easy programming? Where is the best information on this?
http://www.autohotkey.com/
Download Autohotkey and install it. Open the Windows Text Editor, copy paste those 5 lines : Menu, tray, tip, PT personal Shortcuts #CommentFlag // // Event, Time Operations , Change Meter... = Ctrl Shift T ^+t:: WinMenuSelectItem, Pro Tools, , Event, Time Operations, Change Meter... return Save that document as, maybe, "PTShortcuts.ahk". The ending .ahk is of importance. Run this script. Now Ctrl Shift T will perform the command. I have a lot of those PT menu commands without an official shortcut assigned to own shortcuts via Autohotkey. With a programmable keyboard, those commands are now a single button press operation, a workflow revolution for me (with the help of moderator Shan, the king of Autohotkey ).
Fantastic. I will use this in the coming days. I ignored this possibility. Joachim, thank you for your time, especially for details.
It is really a workflow enhancer, but it requires work and has limitations :
What are the free shortcuts, that PT does not use, so they can be used by Autohotkey ? I spend 2 days creating an Excel sheet and searching the Ref Guide and the Shortcuts Guide for all already used shortcuts. An Excel sheet with a list of all possible shortcuts in general and then filled with the found existing PT shortcuts. PT unfortunately does not accept shortcuts made with Autohotkey, that include Alt or Start (or AltGraphics). Selfmade shortcuts are therefore restricted to Ctrl , Shift or Ctrl Shift. One has to make his own "Personal Shortcuts Guide" to keep track of the selfmade ones. The "finger-friendly" shortcuts (two fingers of one hand, but they do not need to spread unnaturally wide) are of course already used by PT : one has to live with the rest. But there are nice unused "two-hands-but-only-1-or-2-fingers-of-each-hand" shortcuts left, like those ones, that I use: // Options, Edit Window Scrolling, No Scrolling = Shift Arrow Left +Left:: WinMenuSelectItem, Pro Tools, , Options, Edit Window Scrolling, No Scrolling return // Options, Edit Window Scrolling, Continuous = Shift Arrow Right +Right:: WinMenuSelectItem, Pro Tools, , Options, Edit Window Scrolling, Continuous return // Options, Edit Window Scrolling, After Playback = Shift Arrow Up +Up:: WinMenuSelectItem, Pro Tools, , Options, Edit Window Scrolling, After Playback return // Options, Edit Window Scrolling, Page = Shift Arrow Down +Down:: WinMenuSelectItem, Pro Tools, , Options, Edit Window Scrolling, Page return // Options, Solo Mode, Latch = Ctrl Shift Arrow Left ^+Left:: WinMenuSelectItem, Pro Tools, , Options, Solo Mode, Latch return // Options, Solo Mode, X-OR (Cancels Previous Solo) = Ctrl Shift Arrow Right ^+Right:: WinMenuSelectItem, Pro Tools, , Options, Solo Mode, X-OR (Cancels Previous Solo) return Programming an additional "buttons-only" keyboard requires also documentation and work, the Expertkeys software is not really good, but does the job. The good thing though is : one can use "finger-unfriendly" shortcuts with Autohotkey and assign that one to a button of that keyboard -> instant single key commands. The same applies to PT shortcuts, that are by itself "finger-unfriendly", like "Alt Start Ctrl Shift L" : a one time work, to put those on the "button-only"-keyboard. It took weeks to define/refine all this, but I will never go back .
I see, it's a bit complicated. With Cubase or Nuendo, it takes a moment! But I returned to Pro Tools for recording purposes and mixing, and even MIDI (it is not everything but it does very well done). So I have to cross this step. Thank you for your information.
no " Level Meter " on Master Track | Peter Kroner | Windows | 11 | 04-16-2023 12:10 PM |
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] | andrew24c | macOS | 4 | 07-23-2014 07:21 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
