Master & slave systems, 'freewheel'
Hi All,
I'm running two Pro Tools systems for a live show, one main, one backup and need to know (aside from pressing play at the same time on both systems) if there's a way to sync the start time of the two systems but allow the slave to 'freewheel' (possibly wrong term) if the main system goes down. Currently I'm using a PT10 system with apogee symphony for the main and a PT10 Profire 2626 system for the backup although that will change from show to show so if you do have any ideas, don't worry about the specifics of my current system. Many thanks JW
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
Re: Master & slave systems, 'freewheel'
In the session setup window (Command+2) there is an option to freewheel or jam.
Thanks for the reply Chief, I'll give it a go tomorrow.
Don't forget your Radial SW8 Switcher. If you're running 8 outs and below on both systems, you need one. Anything about 8 outs on both systems, you'll need two SW8's.
isn't it possible to lock multiple units together with smpte.
Pro tools does this free ( i think ) and should only require 1 out on the master and 1 in on the slave. I know for fact that in the early days smpte was used to lock SSL consoles to Pro Tools. Well not lock more like sync IV NEVER TRIED, THIS IS JUST A GUESS |
Yes. You need an LTC-->MTC converter or a SYNC peripheral to do this.
The easiest way to do this is just do it via Midi and let the two computers chase each other. Stop A, then B continues, Stop B, then A continues. They keep running until you take them OFF LINE (Command+J)
You can also use 1 network cable between the two computers, but two Midisports works the best for my rig. Last edited by vinlance; 08-31-2013 at 12:27 AM. |
master and slave issue | John Rose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-14-2010 05:43 PM |
PT 9 pin slave and master | virtual23 | Post - Surround - Video | 0 | 01-27-2007 07:36 AM |
HOW do I Make a MPC the master and PT the slave | Raumin | Tips & Tricks | 1 | 03-15-2005 02:36 AM |
Master or Slave | smmdrum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-01-2003 09:37 PM |
slave or master | Mike Glenn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-04-2000 06:34 AM |
