Consolidate Regions issue
can't consolidate audio regions, destroys the audio and waveform is
like white noise. Midi regions consolidate without problem. had this already with other versions. ...anybody else ?
wolfgang funk marrakech prod www.marrakechprod.com www.linkedin.com/in/marrakechprod https://pro-labs.imdb.com/name/nm3047395 ------------------ Mac Pro 2.8, 8 Core,16 GIG Ram, PT HD 10 - 12. Mac Book Pro 2.6 Retina 16 GIG Ram, Artist Control/MIX. |
Re: Consolidate Regions issue
nobody ?
What troubleshooting have you done? Help us help you by reading the HELP US HELP YOU sticky at the top of this page. ff
Seriously.
What kind of rig? What specs? Which version of PT ???
... but does it help the chorus? |
I wrote the sticky HUHY threat, also the previous posts.
My invert plug is also in the plug folder, did repair of permissions, was looking for read and write permissions in the project folder's audio, fade folders. Trashed preferences ..... can't do a new install now because of work for clients, but.......there is of course the gain plug, it works normal and I created a QuicKeys shortcut for this. Process without changing the gain. thank you ff and sean !!
....sorry PT Lover, but it's the "invert-duplicate" plugin.
Anyway, back to the problem at hand. I wonder if the DAE Prefs can get corrupted? Have you tried to delete that folder to make PT re-scan the plugin folder?
may be the plugin is corrupted ? is this possible ? tomorrow I do a new install from scratch. Hope that helps. Even if it's not a big issue it's disturbing. thank you PT Lover !
It's working again :)
Used the menu command once and it worked, so I thought it's the shortcut, tried the shortcut again and it worked. Mysterious !! thank you all guys !!!
PT8 midi regions consolidate on their own........ | MEAT | Pro Tools TDM Systems (Win) | 4 | 01-07-2011 03:06 PM |
Problem: Cannot consolidate regions | wwittman | Pro Tools TDM Systems (Mac) | 2 | 07-09-2006 04:39 AM |
consolidate regions help | lala | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-24-2003 12:22 AM |
Consolidate Regions is 'grayed' out | jsampedro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-22-2003 10:33 AM |
best way to consolidate regions | smlworld | Pro Tools TDM Systems (Mac) | 3 | 05-21-2001 10:35 AM |
