Re: My hardware system has never cut it.
What interface and driver version are you using?
The original i7 was 1366 pins, your CPU is a cut down version... Bigger Buffer size will give the CPU & SSD time to think... 1024 recommended for mixing... As low as possible for recording, 128 usually, 64 @96KHz needs very advanced hardware. When session stops is usually because the SSD are too slow, not fast enough, or CPU is not fast enough, or Windows is not optimized or Bios... Mixing different memory modules, not recommended... Test memory, remove similar pairs... http://www.memtest.org/ Many people complain that ProTools is not compatible with i5,
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. |
You need to install ILM, the correct version of your interface driver for the OS you are on, Pro Tools, and follow *all* the systems optimization instructions in the Pro Tools Installation Guide. In the playback engine dialog make sure "ignore errors" is *not* checked (you want to see every AAE error Pro Tools gets upset about). And make sure "dynamic plugin processing" is also not checked. Start with a IO buffer size of 512, increase it if needed as far as it will go to see if you get something stable. Decrease to see when it breaks. Try just working with 48Hz sessions (not faster) until things are stable. If there are problems go run down the standard troubleshooting steps ("help us help you" top of this page). Trash prefs, try new empty sessions, temp. remove all third party plugins, etc. etc. all that you should be doing without needing to ask about here. But tell us exactly what you have done when reporting back. Unless you are going to discard/sell the laptop, I'd be ordering big new DIMMs for this laptop, they are cheap and nice wether you use the laptop for Pro Tools or not. You need to check the onboard SATA support, if it's SATA III/6 Gbps I'd be upgrading the boot drive as well. Even if that has nothing to do with any issues, its just danged nice to have a fast SSD boot drive. If there is a second SATA III slot shove another SSD in there. The disk cache feature in recent Pro Tools 12 may be a large help to you on this laptop if you cant get faster SSDs on it. Unfortunately Pro Tools 12.5 and 12.5.1 are a bit of stability disasters. Pro Tools 12.4 is ideally what I'd try if you have that installer in your account or can get one from somebody else. |
Hello Again;
Well, I'm still on Version 10, but wanted to possibly expand the system or get a new one, that would handle the newer requirements. That's why I posted in the 12 section. For now I would be looking at version 10 so this is probably in the wrong section. It looks like I could go over the replies, & see what modifications I can get going. I could also apply some of the suggested settings & see how that helps for starters. Thanks, again; Rob_D |
Hello;
I had done some jpegs of previous errors, & was trying to attach them for reference. Error 6085, & 9128. Regards; Rob_D |
#16
Again, what exact interface and driver version are you using? What io buffer size are you trying to run at? 6085 are frequently related to driver issues, FireWire chaining problems etc.. Try a different interface. If using ASIO4ALL, don't, get a proper ASIO interface. Everything else is back in your hands... Is/was the system fully optimized, what standard troubleshooting did you try when there were these problems. You need to actually use the system now and see how it goes and do all that stuff. Nobody here will likely be able to point out a cause of a problem to you. But get the memory DIMMs better matched.
#17
Wait, you are running Pro Tools 10 Express, based on your screenshots and your profile. But you don't bother to mention that here, not when asked for clear exact info?
Maybe a moderator can move this thread to the correct Pro Tools Express forum section. |
#18
Hello;
Yeah; I did mention it. I did two posts in a row this before the error images. Here's the previous post again. Hello Again; Well, I'm still on Version 10, but wanted to possibly expand the system or get a new one, that would handle the newer requirements. That's why I posted in the 12 section. For now I would be looking at version 10 so this is probably in the wrong section. It looks like I could go over the replies, & see what modifications I can get going. I could also apply some of the suggested settings & see how that helps for starters. Thanks, again; Rob_D |
#19
Hopefully a moderator will move this to the Express forum section and you can come back and report what is happening after you have upgraded memory, and provide more clear information about what exactly your setup is and what exact troubleshooting you have done. Last edited by Darryl Ramm; 06-26-2016 at 01:12 PM. |
#20
What buffer size are you on when you get those errors?? If you are at a low buffer and have a decent amount of plugins and such, it would explain it as you would need to raise your buffer size.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Recommended Hardware for a PT 8 LE system | charlesd81 | General Discussion | 1 | 11-24-2010 07:30 AM |
HD9--Can I now use HD hardware for PT and Mac system simultaneously? | bashville | Pro Tools 9 | 2 | 11-06-2010 02:18 PM |
System Compatiblity and Hardware | beatnick fly | Pro Tools M-Powered (Win) | 7 | 03-11-2009 07:45 AM |
Need suggestions on system and hardware | jbiss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-13-2002 03:43 PM |
New system -- hardware to avoid? | clarkepr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-08-2002 09:50 AM |
