Old 06-12-2003, 02:34 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default fAde shaPe and tRim buG in PT6
Do this to see what I mean . . .
**************part 1 **************************
1. Session with 2 audio regions.
2. Put a fade-in on each region (smart tool or D key) so that you have two fades with shapes derived from your prefs.
3. Select the fade-in on either region, call up the fade dialog with command-F and change to another fade shape.
4. Go to the other region and with the smart tool change the fade in length (either shorter or longer)
Result = the new fade will be the same shape as the one created in step 3.
**************part 2 **************************
1. Now place the cursor either in the fade-in or in the region and type "D" for fade in. The fade should still be the new shape.
2. With the trimmer make the fade shorter or longer
Result = the fade will revert to the shape in your prefs.
Same thing happens on fade outs as far as I can tell.
6.0.1 - 10.2.6 - Mix24
noise | jimlongo
Old 06-17-2003, 12:07 AM
jimlongo's Avatar
Default Re: fAde shaPe and tRim buG in PT6
So is it that no one can duplicate this, or that no one cares to try?
noise | jimlongo
Old 06-17-2003, 11:09 AM
TCDet TCDet is offline
<font size="2" face="Verdana, Arial">Hi Mr. Longo.
"D,F,G" keys always work off the Pref. settings.
I am not getting the reversion or change here.
Might not be getting your point on a bug.
6.0.1TDM Mix system G4 DP1ghz -OSX.2.6
TC
Old 06-17-2003, 11:28 AM
jimlongo's Avatar
Originally posted by TCDet:
Hi Mr. Longo.
<font size="2" face="Verdana, Arial">i love it when you call me Mr Longo, sonny. [img]images/icons/wink.gif[/img]
The point is that after you use command-f one time then the following trims to other fades using the trimmer change shape as well as the one you purposely changed.
I've tried to eliminate all variables booted fresh with no haxies present and it always happens.
Did you try it carefully step by step?
If a couple more people would verify that they are not affected by this, I will start to wonder what else could cause it. Your system is practically identical to mine.
Thanks, Jim
noise | jimlongo
A bug or the way things are now? (Fade and trim tool turning to pointer)! bashville Pro Tools TDM Systems (Mac) 1 01-29-2010 10:21 AM
Trim-Fade with Smart Tool pfo Tips & Tricks 2 10-04-2007 01:49 AM
PT wont let me trim a cue that has a fade on it Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-02-2006 01:29 AM
Demonic Fade Shape Bug! Stuart P. Post - Surround - Video 32 08-03-2004 07:59 AM
fade trim bug in 6.4, etc. Steve MacMillan Pro Tools TDM Systems (Mac) 1 05-20-2004 08:27 PM
