Old 07-08-2010, 07:59 PM
efernan1 efernan1 is offline
Default Best Pro Tools LE version for old PowerBook G4?
What do you think it's the best Pro Tools LE version for an old aluminium PowerBook G4 / 1.25 GHz / 1 GB RAM running Tiger? Taking in account performance and stability.
Pro Tools LE 6.9.2?
Pro Tools LE 7.3.1?
Pro Tools LE 7.4?
Other?
Thank you!
Old 07-08-2010, 08:13 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Best Pro Tools LE version for old PowerBook G4?
You can run 7.4 on a Power PC G4. One of my computers is running that and it works fine.
I'd suggest more RAM.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-08-2010, 09:20 PM
Hi, thank you for your input!
Well, the problem is that this notebook can't be expanded anymore. One of the RAM sockets isn't working anymore (I read this is a common problem with some PowerBooks) so it only has 1 x 1 GB SODIMM.
Cheers!
Old 07-08-2010, 09:32 PM
mcgwd mcgwd is offline
How ironic, I was about to ask this very question today as well.Decided to use an old ibook g4 1.33 for tracking purposes only instead of hauling my mac mini rig around.
My thoughts were to stay at 7.1, I just need 16 solid tracks will little to no plug ins.Digi 002r + Presonus D8, said Ibook and some mics is all I need.
Was not meaning to hijack, hopefully some others will add more.
Mac Mini Pro 2.53 c2d | 4 GB Ram | OS X 10.6.4
DIGI 002R - Pro Tools 8.0.4 - latest plugins
OWC Mercury Elite w/ 80 GB WD 7200 rpm
Old 07-08-2010, 09:42 PM
Yes, that's exactly the use for this old Powerbook G4 + original Mbox. For tracking. I guess it's more than enough for that task, but also I would like to use it for some editing and light mixing. In the future I will buy something better (MacBook Pro) but now this is working fine and just don't want to throw it away.
Maybe I'll try the 7.4 version but I remember reading about using more resources than previous versions.
Thanks!
Old 07-09-2010, 12:27 AM
Stiff Stiff is offline
Yes, it does. Version 6.x uses less than 7.x. Version 5.x uses much less than 6.x but I guess you don't wanna go there. Also, I think there was a jump in one of the 6.-versions that used notably more than the previous one. 6.7...? Maybe....?
Daily news & reviews
www.ProToolerBlog.com
Old 07-09-2010, 01:11 AM
So... What 6.x version would be better, balancing features and resources' usage?
Hmm... just checked the Pro Tools compatibility chart, and the only 6.x version that could run in Tiger is the 6.9.2 (or 6.8.1 with Mbox 2, I now remember that "special" version just for that interface). All previous 6.x versions are for Phanter.
http://avid.custkb.com/avid/app/self...p?DocId=353149
Is it ok? Anyone?
Thank you!
Old 07-10-2010, 07:28 AM
SKI's Avatar
SKI SKI is offline
Thanks!
Yes it does but to go back to something like 6.9 which is the good 6.x version still loses a lot of functionality.
I would say that 7.4 on that machine is the way to go.
Shame bout that ram slot.
URBAN MUSIC-
(Hip Hop and R&B)
Old 07-10-2010, 08:37 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
7.3.1 is solid as a rock. Lots of folks I know with G4s are hanging there and perfectly happy.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 07-10-2010, 11:02 AM
DJ Romy DJ Romy is offline
7.3.1 and 7.4 indeed... but yes powerpc is more stable for handling PT compare those intel mac...
Mac Intel 2.66,Digi 003r,Logic 8,PT 8,Apogee Rosetta 800,Big ben,Lavry Black AD,Mix Dreams,Neve,UA 2-610,SPL Tube Vitalizer,Kultube,Waves L2,Andromeda,Nord Lead
Pro Tools requires version 9.0.6 or later, but CFnd provides version 9.0.0 Danishan90 macOS 10 02-10-2014 03:11 AM
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but Patrick H macOS 3 11-20-2012 02:46 PM
What PT LE version on Powerbook G4 667MHz tvlyd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-31-2008 05:28 PM
newest version PT on a 1ghz powerbook? Dopamine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-06-2007 10:36 AM
I guess an XP version of Pro Tools will be here before we get an OSX version... ckerian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-11-2002 05:58 AM
