I'm having a very curious problem when working with MIDI with Pro Tools LE v6.1.1, don't know if it's a bug (a very obvious one) or something's wrong with my setup. This is 100% reproducible in any new Pro Tools LE v6.1.1 installation I do: If you select a range of notes in a MIDI track, and then try to change the duration of the selected notes (you know, if you change the duration of a note, in this case all the others change too -this is used to change the sustain of a group of notes-) then in the contiguous MIDI tracks, the notes that are in the same selected range just disappear. Just to clarify I'm not selecting these notes too (of the other tracks), I'm just selecting the notes of the track I want to edit. Please, look at these pictures to see the effect of this problem/bug: Selecting the notes After the changing the duration My (very standard) setup: Asus A7V8X-X AMD Athlon XP2400+ 512 MB RAM DDR333 Micron 80 GB Western Digital 7200 RPM HD 52x24x52 Sony CD-RW nVidia GeForce4 MX440 AGP video card 350 Watt Codegen PS/case Windows XP Professional Digi001 / Pro Tools LE v6.1.1 nothing else... Please note that this never happened with Pro Tools LE v5.31, neither with Pro Tools LE v6.1. Just happens with the latest version 6.1.1 Any input/solution, please? Thank you! |
Please, try it!!! This problem is very easy to reproduce...
Thanks again! |
Hi again,
Something I noticed: it works fine in my other Mbox Pro Tools LE v6.1.1 setup. The problem is specific with my Digi001. Any help? Thanks! |
Do the notes reappear when you click outside the track?
Are you using the trim tool?
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Thank you for respinding. The notes just vanish. They don't reapear at all (unless I undo). Yes, I'm using the trim tool. Thanks! |
I have noticed this problem too, but only when working on a Reason Adapted midi track. I didn't notice a problem before installing the bundle. It's very scarey when your tracks above and below disappear. Just undo and find another technique. It appears to only be tracks that use rewire. I couldn't reproduce the problem when just using the 001's midi interface. I've only been able to summize that it happens when a session has been open a long time; when there has been alot of copying, cutting and pasting; and with several Reason instruments in use.
AFAIK, this problem has been talked about before. I'm of the belief the next PTLE will fix it. |
I too remember hearing this issue about 6 months ago. I believe the solution may have been to zoom in closer to the note when applying trim.
Connecting MIDI Keyboard to Pro Tools 11 (MIDI Studio Not The Same) | Diobility | Pro Tools 11 | 2 | 11-04-2013 11:10 AM |
[Problem] Midi Pro Tools 10.3.5 & Motu Midi Express 128 | Advanced-Productions | MIDI | 0 | 05-20-2013 09:43 AM |
Pro Tools Slaved by Midi Time Code or Midi Beat Clock | DarylBham | MIDI | 5 | 06-14-2009 01:55 PM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
Calling all that write/program midi drums by hand in the Pro Tools midi editor. | Mikey Ace | Virtual Instruments | 2 | 10-05-2008 07:14 PM |
