Old 03-13-2020, 11:38 AM
Ellis Beckwith Ellis Beckwith is offline
Default Spinning Beachball on Transport Stop
Only happens on one particular session. system Usage shows around 35% when playing. 3 of the 4 cores about 20%. Activity 3%, Memory 47%. All VIs committed to audio tracks.
To keep it from happening, I have to wait 2-3 seconds before clicking anywhere else on the screen. Occasionally getting cpu overload errors, as well.
Ellis Beckwith
iMac (mid 2011), Intel Core i5 2.5 GHz, 32GB; Samsung 500Gb SSD, PT 2019.5.0, Avid Control; M-Audio Oxygen 25, Faderport 1
Old 03-14-2020, 12:23 AM
Downtown_BE Downtown_BE is offline
Default Re: Spinning Beachball on Transport Stop
in my experience 3 things can cause spinning balls after transport stop: VI`s (which is not in your case), large Beat detectived tracks like full drum tracks and lots of autotune instances in one session (for example on lots of backings etc.)
both consolidating and commiting solves it!
Old 03-14-2020, 12:44 PM
cwsand's Avatar
cwsand cwsand is offline
Could still be a plugin - have you tried opening the session with all plugins disabled?
You could also try a Save Copy in, or create a new session and import session data.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Pro Tools HD 2020.5
Old 03-17-2020, 08:02 PM
I took your suggestion and open the session with all plugins disabled and that fixd the problem. As yet, have not narrowed it down to one particular plugin.
Thanks
Ellis Beckwith
Old 03-17-2020, 09:06 PM
JFreak JFreak is online now
You probably cannot narrow it down by disabling plugins on the session, because the bogey plugin is still loaded into memory. You need to do it the hard way, as in moving the plugin to unused folders, then restarting PT and reloading session. One by one, as long as your problem is gone. That is the only reliable way to know which plugin needs to be updated.
Old 03-18-2020, 04:09 AM
I get this if I have the Baldwin Parlor Grand piano in UVI Falcon still active in a session. Usually when I render the MIDI to audio and deactivate the instrument track with Falcon on it it goes away. It's not a fault of Falcon but of the piano library itself and that's straight from the developer.
Good to know, thanks
Spinning beachball in 10.3.5 Tad Wadhams macOS 10 01-05-2018 05:00 PM
Spinning beachball ? albee1952 Pro Tools TDM Systems (Mac) 10 03-31-2010 12:35 PM
Spinning BeachBall After Recording colinx1 Pro Tools TDM Systems (Mac) 8 01-19-2005 07:11 PM
DP and spinning beachball audiobrad Pro Tools TDM Systems (Mac) 2 01-14-2005 07:45 AM
Spinning Beachball..... dropking Pro Tools TDM Systems (Mac) 10 10-09-2004 11:09 PM
