Old 01-31-2023, 11:43 AM
soundartsonline soundartsonline is offline
Default Record button on Avid keyboard signals volume, not record/ solution?
Running Protools 12 on Mac OSX 10.13.6 High Sierra
Not sure what happened here, but I used to get record function triggered by pressing the record key on my avid protools keyboard.
All that happens now is the volume thing pops up on the screen.
Suggestions?
By the way, this is still happening after shut down and boot up.
Thanks in advance.
Lisa
Old 01-31-2023, 02:38 PM
its2loud its2loud is offline
Default Re: Record button on Avid keyboard signals volume, not record/ solution?
I'm going to assume you mean the numeric F12 key on the keyboard since you can also use numeric keypad #3 to record
In Mac the Function Keys are automatically enabled for Mac functions. The F12 key is pre designed to bring the system volume up.
Go into you Mac Preference ->Keyboard ->check the box "Use F1,F2, etc keys as standard function keys.
If you recently did a system OS update it's possible this became unchecked.
If you're using the #3 numpad key, make sure in Pro Tools prefs in Operation you have Numeric Keypad: Transport selected
Old 01-31-2023, 05:18 PM
Awesome its2loud! Yes, you are correct. I am referring to the F12 key. Thank you SO much for those tips. I shall try that immediately!!!
How should I record dry and wet signals YYR123 Eleven Rack 17 06-27-2013 02:56 PM
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
Greyed out record button - can't record on those tracks? Ty Ford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2008 02:43 PM
Master Record button doesn't record arm MIDI tracks? Borg ICON & C|24 1 10-29-2007 07:39 AM
