Komplete Kontrol S88 not recognized
I have tried everything that the NI website says to do to get the keyboard working and I cant get it to be recognized to come up as a midi option.
PC/Windows 7 Pro/ PT 11. Any help would be greatly appreciated. |
Re: Komplete Kontrol S88 not recognized
This is a USB connection right? Do you have it plugged into a working USB port? Windows has a nasty habit of having power saving measures turned on by default and they may be set to turn off on your computer. Go into Windows control panel and turn them on. It's kind of hidden a layer or two down from the initial screen.
/Library/Audio/Plug-Ins/HAL/Avid CoreAudio.plugin You might move it to another folder for safekeeping. This plugin is used to support Core Audio with Avid hardware. If that's what you're doing, then you're SOL. Avid is aware of this (I spoke with them at NAMM), but I'd suggest you get in touch with them to keep the subject alive. |
If you haven't already contacted support, do that. And if they've been slow to respond (they often are) check the NI support forums. In fact, do both. I found some good advice on the forum when I had what ultimately proved to be the Core Audio issue Michael mentioned above. A few PC users have been through S-series connectivity issues and their results are posted there.
I spoke with Avid at NAMM about this driver as well as the EUphonix MIDI driver, which causes its own set of problems. They know there are problems with the drivers, but there's no real schedule to get them fixed. Since I don't need either one, I just yank 'em out of there any time I update PT. They seem to come from a time when PT was assumed to 'own' your machine. |
True, the NI forums are only as good as those who post to them, but I got lucky and found someone willing to help and they mentioned the Core Audio issue. Similas S-Series issues w/ windows was being discussed simultaneously, I just didn't read those threads. I'm sure the answer is somewhere in there as it's become popular.
NI Komplete Kontrol hosts VST AU in AAX | Rectifried | AAX Plug-ins | 2 | 01-21-2016 01:28 PM |
Komplete Kontrol S61 | KaneStarkey | Pro Tools 12 | 0 | 11-09-2015 04:14 AM |
Pro Tools 12 with NI Komplete Kontrol | randb1 | AAX Plug-ins | 7 | 05-27-2015 02:20 PM |
PT and Komplete Kontrol | LAMEREALM | Virtual Instruments | 25 | 05-26-2015 04:58 AM |
Loading Komplete Kontrol in Pro Tools 11 | LadyKane | Virtual Instruments | 12 | 05-22-2015 04:53 PM |
