Moving from D-Command to S6 -- talkback routing?
Hi
Transitioning from D-Command/XMon to S6/XMon and having trouble understanding how to handle talkback. I was under the impression that I'd just swap out my old XMon for the new XMon, reconnect all the DSub's in the back and be up and running, but with the need for an external talkback mic on the S6, I'm not so sure. Do I need to replace the DSub on the XMon's TB/LB/Util connection with the included breakout cable? And what else is going through that TB/LB/Util connection that I'd be disrupting if I replace with the breakout cable? I didn't do the original wiring for the D-Command/XMon, so I'm kind of flying blind with understanding all of the monitor routing. Maybe I'm missing something basic here. . . appreciate any help!!
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Re: Moving from D-Command to S6 -- talkback routing?
I'm seeing that in my current setup, the TB/LB/Util d-sub is feeding my Mini speakers as well, so switching to the breakout cable would require some re-wiring in order to preserve use of my mini speakers. On the d-command it seem that the built-in talkback mic was feeding the xmon through the 15-pin cable that connects D-command to Xmon. Is that no longer the case with S6? I realize there's no built in mic, but if I connect a dynamic mic to the XLR input on the back of the S6 master module, is it NOT being routed through the 15-pin cable anymore meaning that I MUST run an XLR for talkback mic. Or can I essentially just use all the same wiring as current with D-command and then just add a mic to the XLR input on the S6?
I'm pretty sure the breakout cable goes to the Control D sub not the Talk/LB one. Heres the guide XMON S6 Guide
The Talkback connector on the Master Module is just a pass-through mount so yes you would need to run a XLR cable from the back of the Master Module to the XMON (either the TB I/P on the breakout cable or the second TB I/P on the LB Dsu. Check the guide for the type of microphones needed for each connector. |
I don't see any mention of dynamic mics for talkback -- can I use an SM57 or similar and go directly into the breakout cable or would I still need a mic pre despite not needing phantom power? Thank you! Gary
You should be able to connect it to the 25 way D-type TB2 input and not need a pre. TB1 does need a pre.
Thanks very much Eddie. Transition anxiety! Sent from my iPhone using Tapatalk
C24 routing talkback to Cue mix | gmcambra | Pro Tools HDX & HD Native Systems (Mac) | 4 | 06-14-2015 08:59 PM |
Talkback Routing C24 with DIGI002 | Ghostwood Records | ICON & C|24 | 2 | 04-10-2011 10:54 AM |
Help routing talkback into Pro Tools w/o latency.. | ruzonmoss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-03-2004 11:32 AM |
Signal Routing w/talkback | soundasylum | ProControl, Control|24, Command|8 | 7 | 07-20-2001 12:50 AM |
