12.8?
Any at 12.8 with a D-Control (Bluey)?
Stef. |
Re: 12.8?
Basics work, no new firmware loaded (unsurprisingly).
Only run a stereo session so far so don't know what the higher order panners do, I'm assuming the 7.0.2/7.1.2 won't work properly on the surround panners but hopefully the 5.1 will be the same as before. The D-Control ES are still supported so the surround panners Should be updated to work with 7.0.2 / 7.1.2 at some point but I wouldn't hold my breath. Pete |
Re: 12.8?
Ok, tried a 7.1.2 setup and it basically works - with limitations. The joystick works, the knob only performs the pre-existing functions and can't be assigned to be a height control unless... I was able to have the left hand panner as an X-Y panner (you can switch pan modes/view from the panner but not into theater view as obviously the D-Control doesn't know about that mode, you have to do that on a Pro Tools pan view but it does then work) and have the right hand panner custom assigned to be a height control. Could definitely be improved with a firmware update but workable basically.
Pete |
