Apogee Duet FW apogeepopup reportcrash
This is just in case it might help someone in case they find themselves in my position just the other day:
I bought a used Duet Firewire in fine condition to use with my small home setup: Mac Pro 3.1, separate boot partition only for PT use: OS X 6.8, PT 10.3.10. I installed the driver and software, and things seemed to work fine. However, I noticed a process called reportcrash almost maxing out my CPU every ten seconds. Didn't cause actual problems initially, but I didn't like it much. Activity Monitor showed the process called apogeepopup launching and crashing at the same time. I tried all the different versions of the apogee software I could find, but no luck. Then I searched google for "apogeepopup crash" and I found this: https://www.google.no/url?sa=t&rct=j...S7XofNRTKKJ06g It turns out apogeepopup (a little indicator window that shows the value on-screen when you turn the Duet controller) needs the Arial font to be installed and active, and no crash. Everything is fine. I just activated Arial with the application Font Book (or font manager or whatever it's called in other languages). Many thanks to mattkramer, and I must add, My Duet in combination with my Dynaudio's sound FANTASTIC! Ben. Last edited by Ben Jenssen; 12-06-2015 at 03:43 PM. |
Re: Apogee Duet FW apogeepopup reportcrash
Hey i found this when i searched for duet FW as i'm just about to buy one and Im running PT 10.3.10 and Mountain lion on my macbook pro.......thanks for that headsup......PT 10 is just so stable and perfect on all my mac's , i'm doing 3 tv series as we speak, and sadly for avid, i'll probably never change unless they implement folders and buy out SoundMiner and build it into the system....
www.kfaudio.ca |
BTW, PT 12 free runs fine, as i downloaded for a test , and may be tempted if they implement folders someday
www.kfaudio.ca |
Good luck with the Duet FW. I still use mine and PT 10 on OSX 6.8. They do the job very well. It gets hot, though. Just so you know. |
Apogee Rosetta 200 (MINT), Lynx AES16e-SRC, Apogee Duet, BBE 882i, OFFERS ENTERTAINED | jrhager84 | Buy & Sell | 5 | 03-11-2013 01:25 AM |
Pt 9 and apogee duet 1 | sidneyjohn | Pro Tools 9 | 1 | 02-21-2013 09:07 AM |
WTB:WTB: Apogee Duet 2 | postman56 | Buy & Sell | 2 | 09-21-2012 05:37 AM |
PT9, Apogee duet help please | lacassius | macOS | 5 | 02-08-2012 07:51 PM |
If your using PT9 with the Apogee Duet..... | Amin7b5 | Pro Tools 9 | 12 | 12-07-2010 10:05 AM |
