"the application pro tools has unexpectedly quit"
new mbox and 867 tibook (pt 6, os X)...rock solid for a couple weeks, now has turned to shat
everytime i start up a session: "the application pro tools has unexpectedly quit" any help appreciated........ J [img]images/icons/mad.gif[/img] |
Re: "the application pro tools has unexpectedly quit"
Does this happen when opening a session?,
This happens to me if I try to start PT by opening a session beffore, starting PT. If this is when it happens, to you, start PT first then open sessions. |
Pro tools quits unexpectedly "solution"
At least it was for me, and it was NOT found on THIS site by my eyeballs, but I will be corrected I am sure. But it bears mentioning NONE THE LESS! Recent Mac systems operate with a 64bit processor by default, and Pro Tools is a 32Bit program. They will "somewhat" work together for a week or so, but with some wonky results. DAW errors, tracking lines are off by an inch, and eventually the crashes come on To put your Mac in 32 bit mode, hold down the "3" and the "2" key together while booting up. It will stay in 32 bit mode from then on. To go back to 64bit mode, hold down the "6" and the "4" at the same time while booting up and you are back(why, I dont know, if you are using pro tools) That took me 2 weeks to solve, but my updated LE8.0.4cs is working like a champ. I dont wanna be a geek, I just wanna make music.... Adam http://www.youtube.com/user/tx644 Mac I7, 2.93ghz, 4GB ram, MBox2 P.S.//// 32 bit mode only uses so much RAM, so if you have 4 GB of ram, YOU ARE GOOD TO GO! Do not waste your money on bigger chips(like I Did) Until you are running 64bit Music Software, save your money for bribing the A&R guy's friend's friend. LOL |
Any chance the problem of my Digi002 crashing every hour (harness replaced twice) could be fixed by the 32 bit mode? My original MBox does not crash.
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? | nickbradbury | macOS | 13 | 09-10-2014 03:50 AM |
Pro Tools 10 "quit unexpectedly" constantly after install! | mr punch | macOS | 13 | 01-23-2012 10:46 AM |
"Pro Tools LE quit unexpectedly" tried every solution I can find.... | HorizonsDOUG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2011 11:06 AM |
"Pro Tools LE quit unexpectedly." | pieteronvashon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-01-2010 04:29 PM |
"The application Pro Tools LE quit unexpectedly." | molossus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2009 12:06 AM |
