Old 11-02-2022, 04:48 AM
ShadeTek ShadeTek is offline
Default Source Connect Issue
Is anyone having Source Connect issues since updating to the 2022+ version?
We hadn't used SC in over a year and went to use it only to find we were getting #120 issues, only curable by uninstalling and reinstalling SC. This however then caused PT to crash to desktop as it loaded the SC plugin.
The only way PT would start if SC was completely uninstalled.
I am on Z440 win 10 hdx/x-mon, sync-hd set up.
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock.
Old 11-02-2022, 06:15 AM
its2loud its2loud is offline
Default Re: Source Connect Issue
2022+ version? That’s very vague as there are 6 Pro Tools versions released in 2022 thus far.
What version of Source Connect?
Do you have Source Nexus?
Did you have a look at this?
https://support.source-elements.com/...arch=101727071
And this
https://support.source-elements.com/...nk-and-windows
Old 01-07-2024, 03:19 PM
cubivore cubivore is offline
did you ever figure this out? i'm having the same issue and have tried everything i can think of.
Old 01-07-2024, 04:14 PM
sw rec sw rec is online now
I highly recommend reaching out to Source Connect on this one. Their tech support is fantastic. (SC-Pro Tools-Windows is a tricky enough combination that the self proclaimed famous “engineering guru” from LA ghosted me altogether, but SC’s tech had me up & running trouble free in 15 minutes.)
Old 01-07-2024, 04:42 PM
thanks for the tip! source elements have been closed during the holidays so i'll try tomorrow.
Old 01-07-2024, 04:55 PM
Good plan. In the interim, make sure you have the latest installer. Once SC set it up for me, it performed flawlessly on Windows….setup on MAC was about as easy as it gets.
Old 01-07-2024, 05:02 PM
The Weed's Avatar
The Weed The Weed is offline
I second S-C's support, they are normally very helpful. The only issue I've had with v3.8 on Windows is when using the AAX Link Plug-in. I would have intermittent squeaks and squawks in the signal coming from the remote end. No problem with my signal going to the remote end. S-C support suggested using a separate interface for S-C, but, since I have RME's TotalMix, I stopped using the Link plug-in and route my signal to and from the Standalone version. This issue on Windows is supposed to be fixed in the so far vaporware v4.0. (One other issue I have run into is not being able to hear the remote end if they do not have port: open, but that is a known issue for some whether on PC or Mac. I always have port: open at my end.)
If you don't need Source-Connect, or as an adjunct to S-C, have a look at www.sonobus.net. Similar to and in many ways superior to Source-Connect - and it's free.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-07-2024, 07:48 PM
I use SC exclusively as a standalone, with a Focusrite Scarlett 2i2 front end. If I need to run Pro Tools simultaneously, all my Pro Tools audio goes thru my UA Apollo 8. I do keep the two separate, so do NOT use SC as a plugin.
Old 01-08-2024, 07:45 AM
My solution was to run it on a separate machine(laptop) and route audio to/from by using a small 2 IO interface on the laptop.
Old 01-08-2024, 08:39 AM
interesting tips on the second interface. I already do this with a DigifaceUSB for SCNow and browser audio for protools HDIO, but always ran the aax link for SCPro. I don't think i'm having any issue with the link plugin since I can't even log in (error120) and do a port test (grayed out), and I've tried running just SCPro with no PT running and get the same results.
HTML code is On
Source-Nexus vs Source-Connect Standard ??? EGS Windows 20 06-10-2022 10:52 AM
Source Connect/ Source Elements/ Anyone? soundartsonline Pro Tools 11 2 02-28-2017 07:01 AM
WTB Source Connect Meads Buy & Sell 0 01-23-2016 01:14 PM
Source ZIP- a new nifty utility from those Source Connect People MIKEROPHONICS Pro Tools TDM Systems (Mac) 0 01-13-2010 09:05 AM
source-elements.com/Source-Connect clusterer Pro Tools TDM Systems (Mac) 3 10-30-2005 05:16 AM
