#51
Re: Horrible VI performance when recording in 2019.10!
Sadly, that's what I'm doing at the moment. No other way. On 2019.10. |
#52
Wasn't PT 12 supposed to be better than PT 11 performance-wise? I took it back one more PT level than you did to prove a point that performance in 2019.6 is better than previous versions. If you can't grok that then I don't know what to say. If PT 2019.6 and 2019.10 performance was as bad as you're saying there'd be a LOT more people bitching about it here. Especially people like Southside, Darryl, Janne and others.
#53
I don't know what you are trying to achieve or trying to confuse me with.. I said the specific versions i had great results with, and now I am saying the version I am not.. there's nothing untoward, deliberately misleading, nada. I am just saying how it is for me.. it wouldn't matter whether PT5 was the one that gave the new audio engine, or PT 2060.. I am specifically referencing the releases and the different performance between them. There was one release of 12, i can't remember which one.. which did exactly what 2019.10 is doing to me here.. and it was fixed in the next point update.. which is why I hope it can be fixed.. Again.. no one will notice this unless they are literally at 80% on every core in a heavy project.. as I said i only noticed it cause projects that were borderline on previous versions can't play back now. You really are weird.. you go from nice to insulting in 2 seconds.. I think it's a game you play.. I can "grok" that. It seems that you can't.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
#54
I checked your profile but need to ask.. what CPU are you using or mac model? I am going to ask you a huge favour.. to tell me the number of logical cores you have, so I can work out the maximum theoretical real cpu PT has access to, and ask you to open up activity monitor and tell me at what percentage it can't play a project back.. This will hopefully be in line with my findings (since the low buffer stuff is) which means I have more backup to go to Avid with. For example, if it's an 8 core 16 thread, max cpu is 1600%. If PT 2019.10 is letting you use say 1000% only, then you have the same issue as me for playback tracks (unrelated to the low latency issue). It should be more around 1350% as with previous versions. (theoretical max is 1200% for 6 core, 800% for 4 core, as long as it's a hyper threaded cpu you just double core count and multiply by 100% to get the maximum available cpu usage available to the mac) All this means is that you can use less plugins than before but with a decent mac you won't notice it unless you are doing a large orchestral mock up or something that really taxes the cpu.
#55
#56
"You have to work at 32 if you want a respectable roundtrip to use the DAW as your actual mixer for all sources"
You have no idea how many times I have run FOH system at 256 buffer, producing house sound and monitoring without a single complaint about latency. Also good to know if a synth isnt a VI then its roundtrip is added latency. Somehow musicians can play if you dont tell them any numbers. They assume it is analog until the threshold of delay being unbearable. That is 512 buffer.
#57
#58
I am talking about real world latency experienced by musicians on stage. There are only two types of latency: too much and good enough. If you dont tell them numbers they are okay with 256 buffer. Period. That is my point.
#59
On stage is probably more forgiving than studio work.
#60
No. It is a matter of being able to monitor yourself. If the latency is too much you hear delay. If it is good enough you do not. Physiological fact.
Only thing different between stage and studio is not many divas want to tell the audience that he or she doesnt feel good right now so just lets try another time and/or blame someone else. In studio you can do that. Either your water is too hot or too cold or whatever, but on stage you have one chance to satisfy your audience. That is the only difference. (and btw I have been running monitors on studio conditions at 256 as well. when someone asks to lower latency I just mute the monitors for a second and say it is done. works 99% of the time)
PT 2019 Mojave performance improvements | bartosz idzi | Pro Tools 2019 | 8 | 05-17-2019 01:10 PM |
Horrible Latency when recording in Pro Tools 11 | FJ92 | Pro Tools 11 | 4 | 04-22-2016 10:09 AM |
Recording quality suddenly horrible? PT8 - files in here. | masta1 | Pro Tools M-Powered (Win) | 7 | 04-03-2009 10:11 AM |
Horrible noise on bass amp when recording! | idledude | Pro Tools M-Powered (Mac) | 6 | 01-07-2009 12:57 PM |
Horrible, Horrible, Skreeching Noise On Drum Track in Sampletank | William.E.Lemuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2002 06:54 AM |
