Re: Strange "Assertion" error causing Pro Tools to quit unexpectedly...????
I have that very same error, here´s my description from my own thread:
"Hi there, I have a severe problem with my ProTools 10. I´ve been working this session for quiet some time and everything used to work perfectly. Now I´ve been getting the attached error message when starting playback of a highlighted playlist clip. I can´t do anything in ProTools from then on. I can only manually shut it down by using the task manager. the problem occurs again after restarting. here´s a picture of the error: http://img.photobucket.com/albums/v6...03um133729.png written out it sais: Assertion in "/Volumes/Development/ws.Ludwig/Altura Ports/PT4_App/Macbuild/../../NewFileLibs/Time/Time_TypedBase.h", line 140 The last number changes every time I get the error. When I click ok it just pops back up. I have deleted the pro tools databases and tried to delete the digidesign files in the preferences folder, unfortunately there were no digidesign files in there though . CAN ANYONE HELP ME? My system: Focusrite Saffire Pro 40 Macbook Pro 15" Mid 2010 8GB 1067MHz DDR3 ram, 2.4 GHz Intel Core i5 Mac OS X 10.6.8. ProTools 10.1.2 Western Digital Mybook studio 2TB Firewire 800 Buffalo Drive Station 500gb Firewire 800 "
Focusrite Saffire Pro 40 Macbook Pro 15" Mid 2010 8GB 1067MHz DDR3 ram, 2.4 GHz Intel Core i5 Mac OS X 10.6.8. ProTools 10.2. |
I was wrong! stvbn, you were absolutely right to look to the elastic audio plug-in. I was confusing the timebase selector with the elastic audio plug-in.
As it turns out, regardless of the timebase selection setting, the assertion error occurs in the manner I previously described only while elastic audio is enabled on the track. If the elastic audio plugin is set to "NONE - Disable Elastic Audio", the error does not happen. An Avid support tech was able to replicate it on his end, and it looks like it's a bug in PT10. |
I found a solution!! It has something to do with either the cached wave files or the elastic audio or both. What you do is: Exit out of pro tools Go to the session folder belonging to the problematic session. DELETE "WaveCache.wfm" Re Open pro tools/ session and let it re draw the waveforms. THEN disable elastic audio OR enable and disable. Simply deleting the wave cache didn't help until i turned elastic audio ON once it re-renders all the audio files in the playlists you can turn it back off. |
I am STILL getting this problem on 10.3.9...
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
"Pro Tools quit unexpectedly" a lot! | MidnightFlyer | Pro Tools 9 | 0 | 06-29-2013 03:05 PM |
Pro Tools 10 "quit unexpectedly" constantly after install! | mr punch | macOS | 13 | 01-23-2012 10:46 AM |
"Pro Tools LE quit unexpectedly" tried every solution I can find.... | HorizonsDOUG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2011 11:06 AM |
"the application pro tools has unexpectedly quit" | lcovemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-19-2010 12:33 PM |
"The application Pro Tools LE quit unexpectedly." | molossus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2009 12:06 AM |
