Can older Eleven Racks take the Expansion Pack?
Hi!
After just going through a cumbersome process of updating my older (2009) Digidesign-era Eleven Rack firmware up to v. 1.0.3 I'd like to get myself in more trouble by getting the expansion pack. Here's the issue that may a non-issue. To update the firmware, I needed to first install the older Digidesign-branded 1.0.8 drivers, since the newer 1.0.11 Avid branded drivers, which installed successfully, somehow kept the 1.0.3 firmware installer application from working correctly. Given that it looks like I may only be able to use these older drivers, will I run into any problem using the Expansion Pack Updater application? Note that I would be using the same Windows XP machine. I do not use Protools and do not intend to use it. I just want to upgrade the firmware to 2.0.1. to add the added features. |
Re: Can older Eleven Racks take the Expansion Pack?
mine was bought around October-December 2009, i think? haha I can't even remember what I had for breakfast most of the time. I guess it was one of the earlier ones released with a metal nut/washer as opposed to a plastic one, if anyone here on the forums remembers that particular defect.
Anyways, I've had an 11R since near to it's release date, and I have had zero trouble with the ERXP. the only problems I had was my eyes not reading the manual. lol
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
Definitely, yes!
Chris Townsend Guitar Products Architect Digidesign, A Division of Avid, Inc. |
To use the new avid drivers, you would need to update the eleven rack itself to the new version, and then you can use the avid drivers. I'm almost sure this is how it will work. |
HELP - Eleven Rack Expansion Pack | hamishhowward76 | Eleven Rack | 23 | 08-22-2017 01:11 PM |
Eleven Rack II or Expansion Pack II ? | ofp | Eleven Rack | 51 | 07-22-2013 08:36 AM |
Eleven Rack Expansion Pack | Legion6789 | Eleven Rack | 6 | 01-10-2012 10:23 AM |
Eleven Rack Expansion Pack | Hank Marvin | Eleven Rack | 16 | 08-31-2011 06:12 PM |
Eleven rack expansion pack | reycantong | Eleven Rack | 11 | 01-25-2011 01:31 PM |
