Old 06-11-2018, 04:55 PM
hmac hmac is offline
Default Velvet 2 problem
I installed the Velvet 2 trial version and used it in a couple of sessions, realized I was doing just fine with Kontakt, and stopped using Velvet. In one session, I had inactivated Velvet as an insert. In another session, the Velvet insert track was still active when I closed the session.
So the trial period ran out. Now, when I try to open the session where the Velvet track was left active, I get the Velvet nag screen with 2 options, "Activate" or "Quit". I don't want to buy the license so I have to choose "Quit", which quits Pro Tools every time. Other sessions open fine.
I got a response from Avid support which advised uninstalling the License Manage, reinstalling and syncing my ilok. Problem persists and support seems to have gone dark.
iMac 27" (mid 2017) i7 Quad core, 4.2Ghz, 48GB RAM, Big Sur, 1 TB internal SSD + external SSD's for recording & samples. Apollo x8, Pro Tools Studio Subscription, Mackie Control Universal, Mackie HR824's, Nektar Impact GXP88 controller.
https://www.youtube.com/channel/UCfX...59WCOqPVnlRZVA
http://soundcloud.com/thinman-studios
Old 06-11-2018, 06:05 PM
Top Jimmy's Avatar
Default Re: Velvet 2 problem
Holding the shift key while opening the session deactivates all plugins. This should get you into the session where you can then delete Velvet.
James Cadwallader
Old 06-11-2018, 06:38 PM
T. Jimmy, you are either a genius or god. Take your pick. Did as you said and boom, the session opened with disabled plugins. I was able to activate just the Velvet insert on the track and delete. Session opens every time now!
Again: problem with Velvet and Transfuser on PT10 NeoAle73 macOS 0 02-07-2012 07:15 AM
Velvet problem since PT10 installation clausiii macOS 14 10-25-2011 06:41 PM
Velvet problem bruce lang Pro Tools TDM Systems (Mac) 2 05-21-2009 06:34 AM
Graphical problem with Hybrid/velvet sleepasylum Virtual Instruments 1 03-24-2009 05:54 PM
Strike and Velvet cause Playback start problem ANP57 Virtual Instruments 3 02-11-2008 02:23 PM
