Old 06-07-2018, 02:09 PM
Scott G Scott G is offline
Default AAF Export settings from Premier
Does anyone have any current information on settings or step by step instructions for exporting AAFs from Adobe Premier that play nice with ProTools. I will be giving it to a group of picture editors I work with. I thought I remembered seeing that someone had a document like this but couldn't find it in a forum search.
Thank you.
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 06-07-2018, 03:11 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: AAF Export settings from Premier
"Premiere settings for AAF export" this search in Google brought up a load of info.
This links to a very useful looking pdf that made sense to me as a longtime video editor (no Premiere experience though) using AAF's the Pro Tools
Andrew.
Old 06-07-2018, 05:31 PM
Thanks Andrew I'll have a look.
Scott
Old 07-22-2018, 12:58 PM
michaelfbates michaelfbates is offline
These are the settings I use that work for me to get an AAF from recent versions of Premiere into Pro Tools Ultimate 2018.4 that retains original files with metadata and file names (assuming they're present in the Premiere session).
Mixdown video: no
Breakout to Mono: yes
Render audio clip effects: no
Sample Rate: 48000
Bits per Sample: 24
Files: Separate Audio
Preserve media directory name: no
Format: Broadcast Wave
Render: Copy Complete Audio Files
It also works if you want to use Render: Trim Audio Files and specify handles.
But honestly, I still have issues with the naming of files and metadata being stripped. But I suspect that's a deeper issue with Premiere and the way certain picture editors and production sound mixers work so probably not applicable!
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1
michaelfbates.com
imdb.com/name/nm4876413
Old 07-23-2018, 02:41 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
This will make the export huge and take a very long time in most cases.
I'd go with the trim audio files option.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 07-24-2018, 04:05 AM
True, but I like to have the option to listen through an entire take to search for alternative material. Also, I don't really trust Premiere to not mess about with metadata so this seems like a good way to just give me the original files without Premiere messing about with them.
And it's not exactly like any of us are short on storage space or internet speed!
michaelfbates.com
Old 07-24-2018, 06:00 AM
minister's Avatar
minister minister is offline
Then you need something like EdiLoad. That will conform the Production Audio files to a PT session.
You can also do it yourself with the Field Recorder Workflow built-in.
I find EdiLoad gives me cleaner sessions faster.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 07-24-2018, 01:45 PM
True, EdiLoad has been on the purchase list for a while, but I've been managing so far with a combination of AAFs and Field Recorder Workflow.
To be honest I'm doing less and less dialogue editing so it's less of an issue for me, and on the smaller projects where I edit dialogue and effects I'm lucky to get an editor who knows what an AAF is let alone an EDL!
P.S. Love your doors library, I was using it all day!
michaelfbates.com
Old 07-24-2018, 06:54 PM
minister's Avatar
You can definitely get there this way. Just takes longer. Then there's money...
Hey GREAT! Thanks for the kind words!!
Tom Hambleton CAS
IMDb
-Starcrash
HTML code is On
Can't export I/O settings AllenSimpson Pro Tools 12 1 07-02-2017 10:06 PM
Here are Premier Pro Settings for OMF Export. Kris75 Post - Surround - Video 9 11-25-2012 02:36 AM
Recommended EDL Export Settings? peter5992 Post - Surround - Video 10 06-10-2012 06:33 AM
mp3 export should remember settings, no? digidesigner Pro Tools TDM Systems (Mac) 1 03-15-2009 02:53 AM
Export i/o settings bug 7.4.2 CS1 tsr2 Pro Tools TDM Systems (Mac) 1 09-15-2008 10:09 AM
