Original MBox output problems
I am having issues with my MBox's analog outputs. Channel 2 is roughly 30dB quieter than channel 1 when using the TRS outputs. The headphone and S/PDIF outputs are fine. It is not a cable issue as I have tested each output using the same cable. The problem was noticed after a sudden burst of white noise during playback.
How likely is it that this can be repaired? Any suggestions?
Pro Tools|24 Mix Plus 3 (6.4.1 cs4) G4 AGP Sawtooth with 1Ghz Sonnet Processor Upgrade 1.5 Gig of RAM. OSX 10.3.4 Command|8 |
Re: Original MBox output problems
Sorry I can't help, but my headphone jacks are completely dead. The opposite problem I guess.
Is your output assigned properly in the Hardware setup in ProTools? Are you sure the speakers aren't the problem?
Mac Pro 2.4 Quad, 8 Gig RAM Snow Leopard 10.6 HD Native PT 10 Omni Waves Platinum NI Komplete 8 API 512c, LA 610 Some Mics, Some guitars Some Songs |
Thanks for the response
I/O Setup is fine and signal is outputting properly via the headphones. It is definitely the MBox itself. I have taken a single line from the left analog output and calibrated my console's input to 0dB. I then switch the cable to the right analog output and the console reads -30ish dB. This test was done with the Noise Generator plugin on a mono aux track panned center. I have also checked outputs with the monitor knob set to input only (to bypass computer playback entirely) and had the same results. Any other thoughts?
Problems Installing PT8 /w original Mbox | justindbutler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-18-2010 06:57 PM |
mbox (original) random pop and click problems | jonnystrides | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-07-2010 02:50 PM |
No volume output with original Mbox/Mac Book Pro | Realfi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-05-2008 08:24 AM |
Mbox (original) LE 6.9.2 control problems | bree5 | MIDI | 0 | 03-10-2007 04:16 PM |
MBox output problems | jascha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-13-2003 01:22 PM |
