002 and digital outs/ins
I wanted to confirm I can do this but it's not clear in the Digi 002 documentation:
Can I use the optical input on the Digi 002 as ADAT input (from another audio interface that is sending audio signal) while simultaneously using the digital RCA S/PDIF inputs to receive word clock synch from a master synchronization device? |
Re: 002 and digital outs/ins
This is a case where u would want BNC cable from ur clock to ur ADAT device; If I'm thinkin correctly, u may get some pops doin it that way; I guess u can always jus test it out & see, but I believe, even if they be small, u may get some pops|clicks...
You can.
002 set to slave to coax SPdif. The ADAT device must receive the same clock from the SPdif device. -or- ADAT device must slave to 002 (which is clocked by the SPdif). If your ADAT pre doesn't have a digital input (must be the master) it won't work. MR
Learn to listen. Listen to learn. |
Pretty much said the same thing; Michael, could u tell us what the devices are that u hav?
Here's another example from what I have done:
Liquid channel>RME ADI-96 pro>Digi 002R Also using a Yamaha 01V96 for ADAT inputs. The ADI-96 pro has the best clock, so it's master. BNC wordclock from it to Liquid Channel (using a BNC "T" adapter) to the wordclock in on 01V96. The ADI-96 will simultaneously output wordclock on S/PDIF. So, I use the analog output of the Liquid Channel to the analog input of ADI-96 pro, use S/PDIF out of the ADI-96 pro into S/PDIF in on DIGI002R. All gear is happy. BNC wordclock is being used on those pieces that have it, and DIGI 002r is happily receiving clock via S/PDIF. I have recorded all 18 inputs this way with no issues. Steve |
192 & Digital Outs | Jeffrey Talbot | Pro Tools TDM Systems (Mac) | 4 | 02-18-2009 07:35 AM |
Digital Ins & Outs | meiseman | VENUE Live Sound Systems | 2 | 07-07-2005 09:37 PM |
a recommended mic/pre with Digital outs for 001 | Andrew Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-06-2002 04:24 PM |
digital ins and outs | Karrot24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-15-2000 08:02 AM |
MiniDisc Digital outs to 001?? | stink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-13-2000 03:15 PM |
