SOS No playback sound after recording
This is very frustrating...hope that somebody can help me... I can record with monitor but it doesn't playbck....
The interface Im using is Duet 2, and I've been recording vocals fine with Garageband and there has been playback after recording. After installing Pro Tools 10 and activation and everything, I can record vocals and everything seems to be fine, I changed the playback engine in Setup to Duet and IO input and output seem to be right, and monitor is on, everything sounds fine while recording, and the initial beep sound to indicate the beginning of recording can be heard. But after the recording, I click play and there's no playback sound, and the output on Duet goes full blast as if exploded and no sound...as if the output is put to sleep, not just that, no sound would come through any other audio resource either, for example if I open iTunes and there would be no sound, and this all happens after recording, and I check the settings on Duet 2 and Pro Tools setups and see NO CHANGE. And then I have to quit Pro Tools and open it again and start all over again so there would be sound while recording, but still no playback sound again and the output is dead again. I've already uninstalled Pro Tools and re-installed it but the same problem still happens. It never happens if I'm using garageband. *I don't have an external hard drive at the moment but the computer has 250G space partitioned. MAC OS X 10.8 DUET 2 USB PRO TOOLS 10 Last edited by andisheep; 04-14-2013 at 06:58 PM. Reason: update system info |
Re: SOS No playback sound after recording
After recording, when playing back : do you have Input Monitoring still activated ?
In the preferences : do you have checked " Deactivate Input Monitoring when un-arming record-enable, while stopped" (or similar, I have the menu in German) When playing back and not hearing something : try Alt+K
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 Last edited by joachim; 04-15-2013 at 10:01 AM. |
Too complicated for me, or for analysing the problem from a distance.
Are you sure, you do not route some bus back to itself (feedback) ? Do you have a snapshot of your mix window (and I/O) setup ? Tried trashing prefs and databases ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thank you so much for helping me out, I have taken some screenshots so you can have a look at the settings and what's happening during recording and playing back.
During recording.jpg playback no sound.jpg playback Duet display full volume.jpg |
url: https://plus.google.com/u/0/photos/1...03526065?hl=en Thank you very much! |
Do you see any level in your Master fader meter when you hit play?
Do you see any level on your track when you hit play? Perhaps, use a second drive as recommended by AVID to record to. Recording to the same drive (regardless if it works with other DAWs) is not recommended.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
A screenshot of just the mix window and just the I/O-setups would be helpfull. (Mac Screenshot : Cmd+Shift+A) In the input section of your I/O setup i might see a doubling of inputs. Do use the aggregate I/O (Duet with Build-in) ? Hard to see something ... . In the Bus-section of the I/O : which bus is assigned to what output ?
Buzzing Sound During Recording and Playback | Tman311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-22-2014 06:53 PM |
No playback sound after recording | andisheep | Getting Started | 7 | 04-15-2013 05:08 PM |
After recording vocals, there is no sound during playback. Why? | sfwdslashx | Pro Tools SE and Essential (Win) | 8 | 10-25-2012 07:21 PM |
No sound when playback after recording | chillax69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-12-2006 12:32 PM |
No sound in recording or playback? | peetr3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-11-2005 11:38 AM |
