reason rack plug in issue with pro tools 2020.9.1
Hi - I've created an instrument track and assigned the Reason Rack plug in to it. But the track indicates "no input". When I click to assign an input, under the "plug in" option, "reason rack plug in insert a" is greyed out.
In the edit window, I'm able to record midi, but i don't see any "clips" - just an assortment of midi notes. not sure if this is related or not. It took a few tries before the midi editor displayed anything that I had recorded. Now it does, but it didn't at first, and honestly I'm not certain what changed in order for it to properly display what I had programmed in the edit window. I'm using an Arturia Keystep, which appears in Setup -> Midi Input Devices, but doesn't appear in Setup -> Peripherals -> Midi Controllers. I'm not sure if this is related either. Thanks for your help! |
Re: reason rack plug in issue with pro tools 2020.9.1
While waiting for said info if all you want to do is to input MIDI notes there's no need to do anything in the MIDI controllers. That's only if you want to use any controls on your Keystep. |
Control 24 & Pro Tools 2020 Issue | March314 | Pro Tools 2020 | 2 | 08-25-2020 10:25 PM |
Reason lite and Pro Tools 2020? | itsjustmeee123 | AAX Plug-ins | 2 | 06-30-2020 02:59 PM |
Pro Tools (2020.3) on MacBook Air 2020 compatibility | pellekuipers | Pro Tools 2020 | 1 | 04-04-2020 08:01 AM |
MBOX, Reason 2.0, macbook, pro-tools 7.3 (no reason plug in) | tahiti78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-11-2008 08:11 AM |
Reason 3.0/PT Plug-in issue | jivemaster666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-14-2007 04:13 PM |
