Recording fader movements
So I finally took the time to set-up my Yamaha 01v96 as a controller. It is set up fine and I can control the faders from the 01v96 much like you would with an 002.
I don't seem to be able to get PT to record the fader movements either on Midi Tracks or audio tracks. How would you record only the fader movement on a record enabled track that had audio on it already? On midi tracks it is easy, as you just overlay the info, but on an audio track it wants to record over the exsisting audio. I did search in the manual for about 40 minutes.... : (
International Award Winning Arabic Fusion www.ajmusiconline.com --------------- 2xMacPro 2.66,002r,OSX 10.4.10,PT 7.4cs8 3xVisionDaw,NI Komplete,Yamaha 01V/96 |
Re: Recording fader movements
Enable Auto Write. (Not need to be in record mode). Play & make you moves. Swich back to Auto Read. Make sure Volume or what ever is on in Automation Enable.
Hopes this helps
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Sweet!!
Thanks. It Worked!
Trouble with mouse movements on Leopard install | crizdee | Pro Tools TDM Systems (Mac) | 0 | 01-16-2009 11:12 AM |
Trouble recording Guitar Rig 3 foot pedel movements | Wally9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-25-2008 04:11 PM |
recording from master fader | kindkind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-28-2006 09:10 AM |
01v Fader Movements & PT | davec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-10-2001 05:52 AM |
logic crashes when I record TDM plugin movements | simondo | Pro Tools TDM Systems (Mac) | 1 | 04-03-2001 07:32 PM |
