Old 03-17-2004, 02:51 PM
BenTerry BenTerry is offline
Default Syncing to the PSX-100
I just recently aquired a PSX-100 from Apogee and I was wondering what the best way to clock off of the PSX-100 was. I would rather have it be the clock and I'm not sure how to sync them together.
Any info would be great!
Thanks
Ben Terry
Old 03-17-2004, 04:04 PM
stoneinapond stoneinapond is offline
Default Re: Syncing to the PSX-100
Thanks
How to sync what together? I got the PSX-100 bit but you left the other bit out.
Old 03-17-2004, 05:46 PM
DigiTechSupt's Avatar
The Apogee has SpDif and Adat optical and optical Spdif outputs. You should be able to use the regular SpDif out put with all of out products and the optical outputs with the 001, 002, and 002 rack. You just need to connect the appropriate output on the Apogee to the appropriate input on your audio interface and set the correct clock source in the hardware setup. Check out the section of the getting started guide called Recording To and From Digital Devices. You can download a copy at the link below.
http://www.digidesign.com/support/docs/
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Syncing Mac and PC over LAN se.audio MIDI 0 04-16-2009 02:01 AM
Syncing 6.9.2 the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-09-2007 08:43 PM
syncing qbpoet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-04-2006 07:14 AM
Syncing with MTC Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2002 07:36 AM
Syncing with PT 5 LE????? JRogers General Discussion 0 11-22-1999 11:38 AM
