10.4.10 & PT 7.4 already installed / QT and iTunes Update?
Anyone running 10.4.10 and PT LE 7.4 on an intel mac, do the Quicktime 7.3 and iTunes 7.5 update ?
Everything still running ?
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Re: 10.4.10 & PT 7.4 already installed / QT and iTunes Updat
All you need to do is download the 10.4.10 combo updater (it needs to be the full combo update) and reinstall that. that will get things going again.
Re: 10.4.10 & PT 7.4 already installed / QT and iTunes Update?
IMAC 4 ghz Quad Core Intel i7. 512 SSD Internal + 512 external SSD drive for sessions. 32 gigs ram UAD 2 Apollo Quad core Pro Tools 2021.7 MAC OSX Big Sur |
I have a similar problem -- I've installed Pro Tools 7.4 on a Mac running 10.4.10 and the installer says it failed. On startup, the system is telling me that certain system extensions are installed incorrectly and can't be used... namely DigiDal.kext, DigiIo.kext, and Firewireaudio.kext. When I launch Pro Tools, it seems to behave normally until I try to open or start a session, at which point it tells me that all my (five) drives can't be used to record or play back -- and this can't be changed in the Workspace window. I've tried re-installing the combo 10.4.10 and run the Prebinding repair program as recommended, but it doesn't help. Do I have to downgrade my system to 10.4.9 or does anyone know another fix?
Thanks in advance for any advice.... BILL LANE |
I have the same problem.
Not only with 7.4, but when I tried to go back to the other versions, I received the same error message. I did all the possible fixes/updates/uninstalls that I could do - still nothing is working; and I used to have such a rock-solid system. : ( I emailed Digi tech support; still waiting for their reply
www.propellersound.ca |
I also have this problem
I have a Macbook 2.16 GHz and am running 10.4.10. I was running PTLE 7.3.1 (needed to running pre-binding script to get PT to launch), then updated to the QT and iTunes latest, no issues or need to run the pre-binding script again.
Then I went to PTLE 7.4, no issues at all so far, or, again, the need to re-run the pre-binding script. All working fine. Now dare I go to 10.5!!! I'm in mid project so not yet I feel. Hope this helps. Regards, Anthony |
Please note that Digidesign has not tested and does not officially support OSX 10.4.10. Unless you specifically need to update your OS for other reasons, we don't recommend updating until you have checked the latest Digidesign compatibility information, and NEVER use the Software Update for your OSX updates. Use the Combo Installer from the Apple site instead.
That said, some of the problems y'all are experiencing sound like prebinding issues, which can break when the Software Update OS updater is used. This page is a great resource and has a link to an application which may help fix the 'failure to launch' issues: http://www.digidesign.com/index.cfm?...4&itemid=23954 |
Unfortunately I've already tried that pre-binding repair utility and it wasn't able to find or fix any problems. I wonder if I can use Pacifist to force-install those missing Kext files? Or is it really a matter of reinstalling my system, if I want to use Pro Tools 7.4...?
I am pretty sure it's the Quicktime updates that play havoc with PT's, I don't think itunes hurts anything. I try to stay away from QT updates all together
I can't Play anything on itunes or quicktime after I installed Pro Tools SE | Trazzz123 | Pro Tools SE and Essential (Win) | 1 | 01-20-2013 02:11 AM |
Installed big Ben last week now iTunes plays everything like a chipmunk on 96i/o | MASTERLINKSTUDIOS | Pro Tools TDM Systems (Mac) | 17 | 09-10-2009 09:38 PM |
I INSTALLED 002 RACK AND HAVE SKIPPING PROBLEM IN ITUNES | Jlisted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-02-2007 05:49 AM |
No CoreAudio installed- Should Itunes still play? | Richard901 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-18-2006 12:44 PM |
why cant i find 6.4 update/ installed mix update | mudflaps | Pro Tools TDM Systems (Mac) | 1 | 12-14-2004 07:53 PM |
