Update for ITunes interferes with Audiocore driver
Ever since I did this update for Itunes and Quik time I can't open Itunes if I have my Mbox plugged in. I was reading on a Mac forum that there is some conflict with the Audio driver from Pro Tools and this new update. therefore if I want to use Itunes or anything else that uses the regular audio driver I can't have Pro Tools hooked up. Has there been any updates for the Pro Tools Audio driver that fixes this problem?
[*]MBox [*]Macbook Pro 2.4 [*]Mac G5 1.6[*]Pro Tools LE 6.4 |
Re: Update for ITunes interferes with Audiocore driver
Has anyone had this problem?
Which OS version do you currently have installed?
If is OS 10.3.9 then, yes, there are known issues with that. The problem is the version of Qiucktime 7 that is installed with OS 10.3.9 is not compatible with the Digidesign Core Audio driver. The only solution seems to be either to revert back to QT 6.5.2 (some people have not had success with this) or reinstall your OS, only updating to 10.3.8. |
I actually had the same isues.. I new quicktime update popped up on the updater (7.2, or 7.02) something like that.. anyway.. that seemed to fix the coreaudio problems with QT and itunes..
later -Brad |
Can you play through the ASIO driver using iTunes? | TheLP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-19-2004 03:25 PM |
iTunes and the Core Audio Driver | mboogie1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-05-2003 06:23 PM |
Core Audio Driver v1.2 for iTunes 4 | Avid | Pro Tools TDM Systems (Mac) | 10 | 05-08-2003 11:12 AM |
Core Audio Driver v1.2 for iTunes 4 | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 05-08-2003 12:36 AM |
Bug in Digi Core Audio Driver? Driver update coming? | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 08:59 PM |
