switching windows
Is there a working shortcut for switching windows - from Mix to Edit and vice versa?
The menu says there is one (Ctrl+=) but nothing happens when I try. I sure would appreciate some help! ------------------ |
Re: switching windows
Thats the one. It's the key next to backspace.
.....Not implying that your reading it wrong, but, you should hold down "CONTROL" key while pressing the the "=" key. It might be misinterpreted with the "+" in there. Make sense? When Digi puts the '+' in a command, they mean 'and'.
I had the same problem.
I switched to a English Keyboard because I had the Portuguese layout and "=" was not on the same place as the American or English Layout. If you are not working with a English or American layout I think that it doesn't work. For example, to switch between Mix and Edit windows with the portuguese layout I had to press something like "Ctrl+~+'". I hope this helps.
http://www.facebook.com/EApolonia |
I have the same problem, my keyboard is in Spanish, I guess there are many international users that have the same problem. I think that it should work regadless of the layout that you are using, dont you think???
Camilo Orozco Like us on www.facebook.com/artedigitalestudio www.estudiodegrabacion.com.mx |
Switching from Windows to Mac | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-14-2010 03:30 PM |
Switching to Windows? | roberts | Pro Tools TDM Systems (Mac) | 6 | 02-15-2010 09:23 AM |
Switching to Windows From Mac | mftorso | Pro Tools TDM Systems (Win) | 14 | 07-21-2009 01:31 AM |
Switching from Windows to Mac Pro | Toonvox | Pro Tools TDM Systems (Mac) | 15 | 07-16-2009 09:44 AM |
Switching from Mac to Windows | stagegrin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-01-2002 10:52 PM |
