Old 03-14-2017, 04:22 AM
Cybear Cybear is offline
Default Pro Tools 10 Recorded Tracks disappear when recording is stopped
Hi there, I'm Cybear and I'm new here!
I'm using Pro Tools 10.3.10 and my problem is:
Recorded Tracks vanish/disappear as soon as I stop the recording.
Meaning I can see the progress of the recording (guitar e.g.) but when i hit space or the stop button, the region just deletes itself and doesn't appear in the clips either.
However it IS showing up in the audio files folder which leaves me pretty confused .
Side Info:
The issue appears permanently, it doesn't matter how long the audio file is, if it's a new session or a template, or which Interface I use (I have a Focusrite Scarlett and a Behringer UMC202 which i bought only to test this issue).
I've been using Pro Tools 10 for years now, but the problem appeared rather recently. I switched to windows 10 in roughly the same time period, maybe that's the cause.
I have the hope it's just one tiny checkmark that causes the recordings to disappear.
Thanks in advance for your help.
Pro Tools 10.3.10
Windows 10 Home 64Bit
12GB RAM
Focusrite Scarlett 2i2 USB Interface
Behringer UMC202hd USB Interface
Intel i5 4690 4x3.5GHz
Old 03-14-2017, 04:33 AM
joachim's Avatar
joachim joachim is offline
Default Re: Pro Tools 10 Recorded Tracks disappear when recording is stopped
Pro Tools 10.3.10
http://avid.force.com/pkb/articles/c...tibility-Chart
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-14-2017, 05:44 AM
Thank you for the reply but unfortunately after installing a seemingly compatible version of Pro Tools (12.5.2) the error still occurs. The windows 10 compatibility doesn't seem to be the problem here.
Old 03-14-2017, 06:20 AM
joachim's Avatar
http://duc.avid.com/showthread.php?t=372411
Maybe answers in this thread.
Old 03-17-2017, 06:08 AM
Thank you for the answers. The Solution seemed to be dead simple. My antivirus software was causing the Issue somehow. When deactivated, PT seems to record correctly. (For now at least). Thanks again.
Pro Tools !! (existing tracks being recorded on new ones) ChristChild Pro Tools 11 4 06-14-2016 10:59 AM
Play over recorded tracks without recording on that track? dustinsleeping Getting Started 3 03-30-2014 06:34 PM
Hearing recorded tracks while recording Durstlaw FireWire & USB Audio Interfaces (Win) 6 03-19-2014 11:44 AM
Pro Tools not saving recorded tracks need help The Poet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2007 08:20 PM
help! hearing previously recorded tracks while re-recording batti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2002 02:08 PM
