Optical cable from my Mac Pro into my 192 I/O
Hey all!
I want to connect my Mac Pro Optical Output into the 192 I/O. Got the two 5m cables today in the post. Hooked them up. Read the 192 I/O manual, did all what they said but still no joy!!! I went to the Audio /MIDI setup on the Mac Pro, clicked on the Audio Output as the Optical digital Output setting with 48kHz and 96kHz. Got some audio playing on the Mac Pro (def. works on normal built in o/p) and tried to listen for in coming through on the 192 I/O with no success. Created a new ProTools session with the same sample rates and bit depths etc. 1 Stereo Track. What am I doing wrong? Tried to connect the Optical cable 'IN' for the Optical[Encl] and the ADAT but both were not happening. What should my sync settings be etc... Exte? Internal? Word Clock? Can anyone help? Managed this years ago from the G5 into the 192 I/O with no problems. Are there issues with the length of cable? I hope not. Ta. Phill
I look forward to your response(s). Phill |
Re: Optical cable from my Mac Pro into my 192 I/O
Check the digital input in the Pro Tools Hardware setup. It's a radial button with three possibilities (AES / SPIDIF / Optical Toslink). I believe you want the last one. Then go to the I/O setup and make sure you have an input that says [ENC]. I use input 15-16 for this. Then make sure you have an aux in your session from this input to your speakers. I'm not in front of my system right now, but it works great for me.
Unless he's already using AES or spdif digital, in which case he'll need to decide who wins.
Not wanting to hijack the thread at all, but can you use the Mac Pro internal Optical/Digital out (as a soundcard) then pumped into the Digi 96io as a sound source? (to speakers)
Sorry for being slow here but never thought of that! So you could use Ableton / Logic on the internal soundcard in the Mac and then pipe through into the Digi 96io which is used for Protools?? Can this work for Ableton/Logic playing a simple stereo monitoring through Digital (or is it ADAT?) as well as piping 8 tracks down the opitcal cable into the 96/Protools?? Is the internal Mac soundcard good enough via Digital?? |
Chris
Cool brilliant, but its only 2 track SPDIF stereo and not ADAT (as it looks like an ADAT style cable)?
The new Macpro under Leopard seem to have a fairly complex setup for the i/o ! i can only get either digital or analog but not both? under Tiger G5 i could get both!! really useful. Chris
Optical cable | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-02-2007 11:46 AM |
optical cable distortion | x3rdretina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-19-2007 12:25 PM |
OPtical Cable Mic Pre | roainfo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 03-15-2007 08:26 AM |
ADAT Optical Cable | Alagu | Tips & Tricks | 3 | 07-28-2001 08:52 AM |
Optical Cable | kalasa | Tips & Tricks | 5 | 03-06-2001 07:04 PM |
