How do I make a 6-channel interleaved .BWF?
Does anybody know if there is a program that can join 6 mono files to a polyphonic .BWF? Bonus points if it copies the relevant information of the sources' BEXT chunk to the destination file.
Application: inside ProTools we have a 5.1 mix but the client wants a 6-track WAV file, and we'd like to skip bouncing to disk a 2 hour film in realtime just to get an interleaved file.
A job's not done until it's ready, or the producer is breaking down the studio's door... |
Re: How do I make a 6-channel interleaved .BWF?
Tiago...
The app is called PROTOOLS Seriously - select your 5.1 Mix (make sure it's on a 5.1 track) and do Shift-Option-K. Now select Stereo instead of (multiple)Mono and choose your output destination and formats and voila - A six channel BWF. Re-import it if you want to check it. It works! Apparently Stereo is code for Interleaved...
"Ya canna change the laws of physics..." -Montgomery Scott Howard Sonnenburg Atomic Audio Ottawa, ON Canada |
AAARGH! Really? "Export Selected Regions as Files" will export a region in a 5.1 Track as a 6-ch interleaved file if I select Stereo?? I'll try tomorrow, of course. Why hasn't this option change name to Interleaved already?
Thank you very very much!
It works, but the file names have to have the correct suffixes. Duplicating the selection do help for that
Does anyone make an SSL 4K channel strip AAX DSP? | mtung | AAX Plug-ins | 15 | 09-15-2020 09:01 AM |
Can you change the default channel order of an interleaved.. | dj_grimmace | Post - Surround - Video | 4 | 11-12-2007 08:10 AM |
96K 5.1 interleaved .wav problem | TNagle | Post - Surround - Video | 4 | 06-07-2007 09:27 AM |
how can I get 22 channel interleaved aiff into ... | emdc | Post - Surround - Video | 1 | 09-14-2004 03:23 AM |
SD2 interleaved and Jam | polyorchid | Pro Tools TDM Systems (Mac) | 2 | 07-12-2001 04:45 AM |
