Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 07-01-2012, 01:14 PM
lblanks14 lblanks14 is offline
Default Problem recording guitar
I have my guitar hooked up properly and I can hear it in my headphones and the meter is registering it fine, but when I record it doesnt pick up anything. Any ideas?
Old 07-01-2012, 07:06 PM
Em3xus Em3xus is offline
Default Re: Problem recording guitar
Hi lblanks14,
This is probably a silly question, but do you have the guitar track enabled for recording? You need to select each track to "enabled" on the left, as well as hit the main recording button at the top of Pro Tools SE.
A screenshot might be helpful of when you're recording, and not recording, showing the meter moving and not.
Cheers.
Old 07-05-2012, 11:46 PM
timcrow420 timcrow420 is offline
Originally Posted by Em3xus View Post
Hi lblanks14,
Cheers.
That would be the only thing I could think of. But if you dont arm a track to record and you hit record a pop up message tells you that no tracks are enabled to record.
Old 07-06-2012, 07:45 AM
mysg4ever mysg4ever is offline
Are you seeing transients being recorded? If you are, I have heard that you may need to hit 'save' before trying to listen back at a replay. My pc / pro tools acts quircky sometimes. If the level is not set perfect, I get nothing to play back. I'm only operating on 3gb of ram, may need more. You may need more ram also.
I love my pro tools, but I also have Audacity for simple audio recordings only.
It does not have all the bells and whistles but its free and is never quircky.
Hope you get it figured out.
Old 07-28-2012, 05:58 PM
ChuckD6421 ChuckD6421 is offline
Default Me too
Hi all, my first post here.
In fact I came here for exactly the same problem. I have a Yamaha APX500ii plugged into an M-Audio MobilePre. I also have a mike plugged into it which registers in ProTools fine and I can record. But no luck with the guitar.
I can hear the guitar when I hit the "Direct Bypass" button so I know the MobilePre is functioning. And I know how to arm the track and record for vocals in Protools, but the guitar signal never shows up.
Anyway, I'll start a new thread if this is too different, but I wanted to document a similar problem as the OP.
Thanks for any clues.
C.
Old 07-29-2012, 12:53 AM
DigiTechSupt's Avatar
Question Re: Problem recording guitar
Are you using Audio or Instrument Tracks?
Check out the following knowledge base article:
Can't get Pro Tools to record a guitar or other instrument
Avid Audio Tech Support
Support FAQ
Old 08-02-2012, 06:40 AM
jethrobm jethrobm is offline
Make sure your channel is set to mono 2.
Old 08-14-2012, 04:32 AM
iceCREA iceCREA is offline
i got the same problem. what i did was i plugged my acoustic guitar and i used the audio track, with mono, and nothing came out. previously i did the same using my microphone but it was ok. however i used the stereo option for the audio track it worked, but stereo means the recorded guitar sound is only on one side right? help please? thanks. :)
Guitar recording problem pieroft Eleven Rack 11 01-19-2011 08:06 AM
Mbox Mini guitar recording problem Deamos Pro Tools M-Powered (Win) 1 12-29-2010 06:45 AM
Recording guitar direct + guitar cab TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 07-09-2010 02:21 PM
Recording electric guitar into Mbox mini problem.... thegp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-05-2007 04:47 PM
having a problem getting a good guitar recording.. romerom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 08-28-2005 06:48 AM
