Channel starting to feedback as soon as its record enabled
I am using mbox2 and now I am having this feedback as soon as I click record enable on the channel and it is totally unworkable. I have my setting as Input: IN1 Output: OUT1-2. I went back to setup-I/O to make everything back to default but it still does not work. I am sure the problem is not caused by my microphone because the feedback is still on even when the Mic is not connected to mbox 2 so I am sure this is some PT internal problem. I am not sure if 7.42 is causing this problem but I did not have this problem before I updated my Pro Tool. Thanks for taking the time to read this post, any help will be appreciated. Thanks again.
Re: Channel starting to feedback as soon as its record enabled
need more info, what OS version? What model computer? can you start a whole new session choosing default I/O right from the beginning? not "Last Used" can you try input 2? does it do the same? Did you try restarting the computer for the heck of it?
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
wow, thank you so much. I was too frustrated and I forgot the easiest solution in the world- RESTARTING. Problem solved, thank you so so much!!!!!
Huge delay when sending from a channel which is record enabled to an external send | Thirtythr33 | macOS | 2 | 07-28-2013 01:03 PM |
Get mic feedback while PLAYING song even though no tracks are rec enabled? | awritersparadise | Pro Tools 9 | 3 | 03-10-2011 07:04 PM |
MIDI record enabled and found but wont record | BCRich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-23-2010 12:51 PM |
one channel not starting on time during bounce???? | blumediaprojekt | Pro Tools TDM Systems (Mac) | 5 | 01-08-2006 11:11 PM |
MBox - feedback when record enabled | hprs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2003 10:46 PM |
