ATA, SCSI, or Firewire Hard Drive?
Hi there,
I am finally getting ready to buy a Digi 001 system and a new Mac G4 (466Mhz, 256 RAM)... I'm wondering if anyone can recommend whether I should spend the extra money and get an internal SCSI drive as the dedicated audio drive or if I will be fine just going with Ultra ATA. Also, what about a Firewire drive for this application? Anyone have a recommendation for a good hard drive for audio and a good internal CD-R drive? Any thought welcome! Thanks, -M@tt |
Re: ATA, SCSI, or Firewire Hard Drive?
Do a search on those, it's been covered before on DUC.
SCSI is recommanded by Digi, ATA successfully used by a LOT of users, even internal ATA, Firewire not officially supported yet, but some have been using it. Like I said, do a search , you'll find infos about a lot of things that seem to work pretty well, and much less expensive than the recommanded dedicated external SCSI drive...Good luck |
Note, G4s don't have room for a second CD device, go with firewire CD-R if you have a DVD internal.
I'm a big fan of SCSI, but 001 doesn't need much, I'd recommend the IDE drive. |
SCSI blows for a number of reasons (do a search).
FW is just not quite ready for prime time. ATA works just fine. ATA/66 is OK, if you have a faster bus you may want ATA/100 or better. Use 7200 RPM drives with fast seek times (8.5 or less) and large caches (1 or 2 meg). Use a separate drive for the OS and for audio. If you can't get enough tracks use a third drive and spread the tracks over the two audio drives. Currently the optimum cost-per-GB ratio is on the 45 GB drives. |
In my opinion the best result is given with a ATA/IDE like IBM DTLA-307030.
CU |
Thanks everyone,
I think that, based on the recommendations here and from what I've learned in the DUC, I'll go ATA for both hard drives on my new G4 purchase (probably in a month or two). Now for my next questions... Is there a clear advantage to choosing ATA/100 over ATA/66? ...Even when seek time and RPM are similar? Are the hard drives that can be ordered through Apple with the new G4's good, or should I be looking at buying aftermarket drives for better performance? Recommendations? ...I was looking at the Maxtor Diamond Max plus 40GB drive. Also, is the Plextor PlexWriter a good choice for a CD-RW burner or should I choose the Yamaha model? Will the Adaptec 2906 SCSI controller card work fine or should I choose another card (maybe something faster?)? I've caught a little bit of some talk about problems with the Adaptec cards with the new G4's from this forum, but not enough to really understand the issue. In any event, I just don't want to spend $300 on a card if I'm only going to run my CD-RW from it. Thanks again! -M@tt |
ATA/100 is just a slightly faster cable transfer rate. ATA/100 drives are backwards compatible with all ATA hosts (computers or interface cards).
The G4's have ATA/66 capable controllers and will automatically use best rate that can be negotiated between the computer and the drives. |
If your only use for SCSI is to connect to a legacy CDR burner then any $50 SCSI card will do. You might want to stay within Digi's approved list, however, as the potential for problems is likely smaller when you do.
If your only use for SCSI is to connect to a legacy CDR burner then any $50 SCSI card will do. If you are buying a new burner I would avoid SCSI altogether and go FW. You might want to stay within Digi's approved list for either, however, as the potential for problems is likely smaller when you do.
SCSI Hard drive HELP!!!!!!!! | Ronni | General Discussion | 3 | 07-01-2005 06:42 PM |
PT III SCSI hard drive and disk I/O help!!! | jammanis | Pro Tools TDM Systems (Mac) | 5 | 05-28-2004 08:24 AM |
scsi hard drive suggestions . . . | JEdmunds | Tips & Tricks | 2 | 10-20-2001 02:19 PM |
firewire vs scsi hard drives | spong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-15-2001 10:40 AM |
External SCSI hard drive? | JBlietz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-22-2000 07:45 PM |
