Old 08-10-2020, 02:03 AM
Franklyn Franklyn is offline
Default Re: How to compensate for analog summing mixer hardware latency?
I have the same problem and there is still no solution.
The thing is I want to mix into my masterbus. I think thats a typical way of mixing nowadays. so, if I send my subgroups (dr, vocals, ...) to the analog summing mixer and the summing master out back to the DAW I have some delay witch can not be compensated. And it is improtand to compensate it, because I use automation on the mixbus (after the summing in the DAW) and so it is important that the summing return isin sync with my session.
The only way to compensated (nearly sample sync) is with I/O inserts. but in a summing szenario you should have a 8 or 16 I/O insert to tell the ProTools whats going on. And there is no option for Inserting multi channels of 8 or 16.
the video with Fab is showing how to setup the 2 bus.
https://www.youtube.com/watch?v=0gW18nrUJOI
but his print track is delayed and he is not talking about that problem.
I dont understand why there is no solution in ProTols to compensate summing I/O
monitoring the analog out of the 2 bus makes no sense in a mordern mixing szenario.
Old 08-11-2020, 01:34 PM
The solution to this is to monitor the incoming stereo feed FROM the analog summing. Things to consider:
1-Does the analog summing really make things sound better? Serious question(and no offense is intended), but some folks, insist things sound better when the reality is that maybe they don't, or maybe you might be able to achieve the exact same sonics while staying in the box(several big names in the mixing world are now completely ITB).
2-I know a few folks that mix on analog consoles, or in a hybrid setup(much as you now do) and they monitor the mix off their summing(be it console or summing box) where it comes back into PT and none of them worry about compensation as it doesn't affect what they hear(the returning mix is later than the source tracks, but they are only monitoring the returning mix).
3-If you are not routing ALL audio thru the same analog summing, I see the issue there, and my best advice would be to alter the workflow or setup so that all audio does take the same path(like we had to do back before Delay Compensation when mixing through lots of AUX sub-groups with bus processing).
Just food for thought
Old 08-23-2020, 01:37 AM
finaly I found a working solution to insert an analog summing box with working ADC. I posted it here:
http://duc.avid.com/showthread.php?t=411587
I never found something like this before and I am very happy. It makes it easy to work with analog summing boxes in ProTools.
Best way to compensate for REC input latency? vieris Pro Tools 9 4 07-18-2011 07:35 AM
Stereo dithered mixer with summing mixer? Brahamnesik Pro Tools TDM Systems (Mac) 4 04-16-2011 10:13 AM
Does PT LE Compensate for plugins latency OR NOT? How much!? Retinal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-08-2008 07:39 PM
Nudging a track to compensate for FX latency? skyking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2007 10:08 PM
Does HD compensate for latency WRX07 General Discussion 6 10-10-2005 02:35 PM
