Old 05-24-2019, 02:15 PM
chrismeraz chrismeraz is offline
Default Ctrl Key Doesn't Work
Weird, weird problem. The Ctrl modifier key works only with SOME commands since I upgraded to PT2019.5.
It DOESN'T work with the following commands (nothing happens when I push these key combinations):
Ctrl + A for Select All
Ctrl + Q for Quit
Ctrl + S for Save
Ctrl + Shift + N for New Tracks
Ctrl + = to switch between Mix and Edit windows
It DOES work for the following commands:
Ctrl + Tab to move to next track when renaming tracks
Ctrl + Mouse Drag for fine fader movement
I've tried trashing all preferences. Can you guys suggest anything else?
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 05-24-2019, 03:13 PM
Default Re: Ctrl Key Doesn't Work
Any chance caps lock is on (maybe the caps lock key LED is faulty)? I am not sure it will do this, but worth checking. (Try typing text into some other window/program).
Old 05-24-2019, 03:15 PM
Thanks Daryll. No, the caps lock works properly in other programs. So does the Ctrl key.
Even weirder update: sometimes my Ctrl key works properly in PT. In the same session, without closing and restarting anything, sometimes the Ctrl key will work and sometimes it won't.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 05-24-2019, 03:42 PM
I would pop up the Windows on-screen keyboard and confirm that Windows is seeing the key combinations as you enter them. Also try entering them on the on-screen keyboard.
I recently thought I was going nuts with problems with a Mac keyboard using an app unrelated to audio... we suspect Apple at some time changed some low level key event handling for the numeric keypad keys... anyhow found the issue and got a fix in the application (iTerm2). Did question my sanity for a while.
Old 05-24-2019, 06:48 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is online now
By chance I was reading you thread and I realized my Ctrl + . doesn't work in 2019.5 to stop recording and delete take. Is this working in your system?
What is more relaxing then Music?
GigabyteX79-UP4 Rev 1.1
Xeon E5 2680 v.2. 10 Core cpu Windows10 v.1909
Avid HDX 2019.10 HD - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 05-25-2019, 09:39 AM
Yes, Ctrl + . works for me.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 05-25-2019, 05:22 PM
abc1mce2's Avatar
Update:
Ctrl + . only works correctly if I don't have destructive record set as the record mode. In any other record mode Ctrl + . works as expected.
Don't know if this is the correct behavior so can someone else confirm if this one way or the other?
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 05-26-2019, 04:29 AM
Ctrl + . does not work in Loop or Destructive record. This is expected behaviour. You also cannot Undo recording in these modes.
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 05-28-2019, 04:25 AM
Can anyone help me out? I'm still struggling with this. Not having basic copy and paste shortcuts is killing me, never mind switching between mix and edit views!
Windows 10
Apollo 8
Pro Tools Native
i7 8700K, 32GB RAM
Old 05-28-2019, 09:49 PM
abc1mce2's Avatar
Those shortcuts are working fine on my Windows rig...no problem whatsoever.
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
192 I/O doesn't work with PT 11 HD djkikis Pro Tools HDX & HD Native Systems (Mac) 31 02-24-2014 04:08 PM
8.0.4 doesn't work GuitarMessiah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 07-11-2010 11:10 PM
Two New C24's Mic Pre #16 Doesn't Work!!! MARVINBASS ICON & C|24 11 05-08-2010 11:40 AM
New Toy doesn't work G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2006 02:49 PM
My two day 002 doesn´t work already!!! Punkest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2003 11:07 AM
