Old 10-12-2007, 05:28 AM
John V. John V. is offline
Default Cannot hear Pan in headphones
Mbox 2 (Factory) and Pro Tools 7...
Newby question... no luck looking it up so far. I have imported four WAV tracks recorded externally in to my new Pro Tools LE 7 session. I set outputs on the WAV tracks to 1-2 (stereo) but no matter what I do I cannot hear the pan in my headphones... in other words it is always centered. Interesting enough, when I pan to the < 0 > position, the sound becomes very faint. I have a Master Fader set up, and can hear everything jsut fine (albeit in Mono) when setting the outputs to 1 or to 2...
This is very perplexing to me... and is probably a result of my inexperience with DAW... always have used external records (like MR8 HD) and never had such a problem.
Does anyone have any thoughts?
My thanks!
Old 10-12-2007, 05:51 AM
soundguy_2000 soundguy_2000 is offline
Default Re: Cannot hear Pan in headphones
from your description of the sound becoming soft when panned center, it sounds like a wiring issue. it could be your headphones or a fault with the mbox.
i assume you're plugged into the front output next to the Headphone volume control labeled with a little picture of headphones? make sure your phones are firmly plugged in all the way and if there's a 3.5-6.5mm adapter on the end of the cable, be sure it's properly attached.
what happens if you assign all track outputs to 1 and depress the mono button?
if it goes really quiet, can you try a different set of headphones?
Old 10-12-2007, 01:29 PM
Thanks... I will give that a try and see what happens. Thought I would hook up a pair of monitors tonight as well and see what came through them. I will post when I know...
Old 10-14-2007, 07:05 PM
Hooked up the monitors... worked fine. So I started checking other signal path items... turned out to be a 1/3 to 1/8 adapter for the headphones... puit a different one on and all was well. Thanks!
John V.
Old 10-15-2007, 07:14 AM
Of course, I meant 1/4 - 1/8th...
Can't hear myself in my headphones while recording rtebel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-04-2012 08:28 AM
can't hear my synthesizer through my headphones marieanne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-30-2010 08:42 AM
Hear the input on headphones? possumday Pro Tools M-Powered (Win) 1 10-05-2007 09:04 PM
Cannot hear what is being recorded in headphones Andre White 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-16-2007 08:26 AM
I want to hear metronome in headphones only... DanZ Pro Tools TDM Systems (Mac) 4 10-07-2006 11:10 AM
