Old 10-26-2022, 09:45 PM
b mcgibney b mcgibney is offline
Default How to rewire Reason 10 into PT 2022.9
Did this get dropped somewhere along the line? There are a couple of sounds in Reason 10 I like to use in my songs but was hoping not to have to upgrade to Reason 11 for just a couple of sounds?
Am I missing something obvious here? I'm going to hook up my old cheese grater and make sure I'm not crazy.
TIA Bria
System specs
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
Old 10-26-2022, 10:24 PM
its2loud its2loud is offline
Default Re: How to rewire Reason 10 into PT 2022.9
Rewire was dropped some time ago. If you’re using 2022.9 use Aux IO to go from Reason to Pro Tools. No need for rewire.
Old 10-26-2022, 11:22 PM
OK that will force me to learn that new aspects of 2022.9.
Old 10-26-2022, 11:34 PM
Sardi Sardi is offline
That’s only one part of the ReWire equation. That will get you audio, but not MIDI.
You’ll also need to make use of Ableton Link to sync the transports of the two apps. TBH - not as elegant as ReWire was, but it will work, as long as you’re OK sequencing the MIDI within Reason.
The better solution moving forward would be to upgrade to the Reason Rack Plugin and use that within PT.
Old 12-05-2022, 04:36 PM
Paul Turpin Paul Turpin is offline
OK well - I successfully got reason 12 audio into PT 2022.10 via Aux I/O AND synced the beat clocks via Ableton Link - but HOW do you get the start/stop to work so they start at the same time?!? I'm pretty sure its reasons fault - as the MTC doesn't seem to work. Its so close to working. Does anyone have a workaround?
Paul Turpin
Champion St Sound Studios
[email protected]
Old 12-07-2022, 10:43 PM
YeaH I did the update during Black Friday.
Rewire to Reason raggin Pro Tools 11 0 09-25-2014 07:49 AM
Reason Rewire binty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-19-2010 04:06 PM
Reason Rewire binty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-17-2010 11:12 AM
Reason Rewire josh87 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2007 06:02 PM
rewire reason in PT HELP!!!!!! Livin' Proof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-20-2007 12:04 PM
